  1. Packs
  2. SAMD09_DFP
Overview
The Microchip SAMD09 Series Device Family Pack (DFP) is a CMSIS-Pack that:
Related packs
    - pack: ARM::CMSIS
Devices
ATSAMD09C13A
The low-power, high-performance Microchip's ATSAMD09C13 ARM® Cortex®-M0+ based flash microcontroller is ideal for a wide range of home automation, consumer, metering and industrial applications. It features:8KB of flash memory and 4KB of SRAMUp to 48MHz operating frequencyTwo serial communication modules (SERCOM) configurable as UART/USART, SPI or I2C, two 16-bit timer/counters, 32-bit Real-Time Clock and calendar, one 5-channel 12-bit ADC2.4V to 3.63V power supplyEasy pin migration to SAMD10C devicesSupported by Atmel Studio, ASFSupported by MPLAB X IDE and MPLAB Harmony.
Documentation:
Application Notes:
Additional Documents:
ATSAMD09D14A
The low-power Microchip's ATSAMD09D14 ARM® Cortex®-M0+ based Flash microcontroller is ideal for a wide range of home automation, consumer, metering and industrial applications. It features:16KB of Flash memory and 4KB of SRAMUp to 48MHz operating frequencyTwo serial communication modules (SERCOM) configurable as UART/USART, SPI or I2C, two 16-bit timer/counters, 32-bit Real-Time Clock and calendar, and one 10-channel 12-bit ADC2.4V to 3.63V power supplyEasy pin migration to Microchip's SAMD10D devicesSupport from Atmel Studio, ASFSupported by MPLAB X IDE and MPLAB Harmony.
Documentation:
Application Notes:
MISRA-C:2023 Compliance Deviations List
Deviation ID: MFWCG-40
  • Rule 5.5: Identifiers shall be distinct from macro names.
  • Use case: Identifiers corresponding to register names.
Example:
```C typedef union { struct { uint32_t GPIO:29; uint32_t :3; } vec; uint32_t reg; } ECIA_SRC8_Type;
#define GPIO (0x40081000) ```
  • Reason: Access to hardware.
The macros expand into the same identifiers, which allow users to detect for the presence of specific registers during preprocessing.
  • Scope: Device headers for the DEC15xx and MEC15xx family (<device-name>.h).
Deviation ID: MFWCG-42
  • Rule 20.9: All identifiers used in the controlling expression of #if or #elif preprocessing directives shall be #define'd before evaluation.
  • Use case: Use of compiler builtin macros.
Example:
C #ifdef (__ARM_FP == 14) || (__ARM_FP == 4) fpu_enable(); #endif
Headers may rely on builtin macros from the compiler and are written under the assumption that if the macro is not defined, its value is zero.
  • Scope: All device headers (<device-name>.h).
Deviation ID: MFWCG-43
  • Rule 21.1: #define and #undef shall not be used on a reserved identifier or reserved macro name.
  • Use case: Reserved names, beginning with _ followed by a capital letter or __ followed by a lower-case are within the compiler's namespace.
Example:
C #define __IO volatile
  • Reason: Access to hardware; Code Quality (Usability: Accessibility).
Within these headers originate many reserved names that are within the compiler's namespace.
Deviation ID: MFWCG-44
  • Rule 21.2: A reserved identifier or reserved macro name shall not be declared.
Example:
C extern const VECTOR_TABLE_Type __VECTOR_TABLE;
Support
