- Packs
- PIC32CZ-CA70_DFP
PIC32CZ-CA70_DFP
1.4.79-
Pack Type
Device Support
Microchip PIC32CZ-CA70 Series Device Support
Add to CMSIS Solution
packs:- pack: Microchip::PIC32CZ-CA70_DFP@1.4.79
Add with cpackget
> cpackget add Microchip::PIC32CZ-CA70_DFP@1.4.79
Download
Microchip.PIC32CZ-CA70_DFP.1.4.79.packOverview
The Microchip PIC32CZ-CA70 Series Device Family Pack (DFP) is a CMSIS-Pack that:
- Contains support files for the MPLAB XC32 Compiler.
- Contains support files for the GCC compiler.
- Contains support files for the Arm Compiler for Embedded.
- Contains support files for the IAR Embedded Development Tools.
- Flash algorithms for the on-chip flash memory.
Related packs
- pack: ARM::CMSISDevices
PIC32CZ1038CA70064
PIC32CZ1038CA70100
PIC32CZ1038CA70144
PIC32CZ2051CA70064
PIC32CZ2051CA70100
The Microchip PIC32CZ CA70 devices are a family of Flash microcontrollers based on the high-performance 32-bit ARM Cortex-M7 processor with a Double Precision Floating Point Unit (FPU). These devices operate at up to 300MHz and feature up to 2048 Kbytes of Flash, and up to 512Kbytes of multi-port SRAM which is configurable Instruction and Data Tightly Couple Memories to leverage the advanced DSP capabilities of the core.The PIC32CZ CA70 series includes a 10/100 Ethernet MAC w/IEEE1588, HS USB Interface with integrated PHY, dual CAN-FD, QSPI, MediaLB, CMOS Imager interface, TDM/I2S (SSC,) multiple serial interfaces as well as on-board hardware cryptography including a TRNG, AES-256, and SHA-256 engines.Supported by MPLAB X IDE and MPLAB Harmony.
Documentation:
Application Notes:
- AN5816 - Migration Guide from SAM E70/S70/V70/V71 to PIC32CZ CA70/MC70 Microcontroller Units (MCUs)
- SERCOM USART on Microchip Cortex Devices (SAM and PIC32C)
Additional Documents:
PIC32CZ2051CA70144
The Microchip PIC32CZ CA70 devices are a family of Flash microcontrollers based on the high-performance 32-bit ARM Cortex-M7 processor with a Double Precision Floating Point Unit (FPU). These devices operate at up to 300MHz and feature up to 2048 Kbytes of Flash, and up to 512 Kbytes of multi-port SRAM which is configurable Instruction and Data Tightly Couple Memories to leverage the advanced DSP capabilities of the core.The PIC32CZ CA70 series includes a 10/100 Ethernet MAC w/IEEE1588, HS USB Interface with integrated PHY, dual CAN-FD, QSPI, MediaLB, CMOS Imager interface, TDM/I2S (SSC,) multiple serial interfaces as well as on-board hardware cryptography including a TRNG, AES-256, and SHA-256 engines.Supported by MPLAB X IDE and MPLAB Harmony.
Documentation:
Application Notes:
PIC32CZ5125CA70064
PIC32CZ5125CA70100
PIC32CZ5125CA70144
MISRA-C:2023 Compliance Deviations List
Deviation ID: MFWCG-40
- Rule 5.5: Identifiers shall be distinct from macro names.
- Use case: Identifiers corresponding to register names.
Example:
```C typedef union { struct { uint32_t GPIO:29; uint32_t :3; } vec; uint32_t reg; } ECIA_SRC8_Type;
#define GPIO (0x40081000) ```
- Reason: Access to hardware.
The macros expand into the same identifiers, which allow users to detect for the presence of specific registers during preprocessing.
- Scope: Device headers for the DEC15xx and MEC15xx family
<device-name>.h).
Deviation ID: MFWCG-42
- Rule 20.9: All identifiers used in the controlling expression of
#ifor#elifpreprocessing directives shall be#define'd before evaluation. - Use case: Use of compiler builtin macros.
Example:
C #ifdef (__ARM_FP == 14) || (__ARM_FP == 4) fpu_enable(); #endif- Reason: Access to hardware.
Headers may rely on builtin macros from the compiler and are written under the assumption that if the macro is not defined, its value is zero.
- Scope: All device headers (
<device-name>.h).
Deviation ID: MFWCG-43
- Rule 21.1:
#defineand#undefshall not be used on a reserved identifier or reserved macro name. - Use case: Reserved names, beginning with
_followed by a capital letter or__followed by a lower-case are within the compiler's namespace.
Example:
C #define __IO volatile- Reason: Access to hardware; Code Quality (Usability: Accessibility).
Within these headers originate many reserved names that are within the compiler's namespace.
<device-name>.h).
Deviation ID: MFWCG-44
- Rule 21.2: A reserved identifier or reserved macro name shall not be declared.
Example:
C extern const VECTOR_TABLE_Type __VECTOR_TABLE;- Reason: Access to hardware; Code Quality (Usability: Accessibility).
<device-name>.h).
Support
