- Packs
- PIC32CX-BZ6_DFP
PIC32CX-BZ6_DFP
1.5.90-
Pack Type
Device Support
Microchip PIC32CX-BZ6 Series Device Support
Add to CMSIS Solution
packs:- pack: Microchip::PIC32CX-BZ6_DFP@1.5.90
Add with cpackget
> cpackget add Microchip::PIC32CX-BZ6_DFP@1.5.90
Download
Microchip.PIC32CX-BZ6_DFP.1.5.90.packOverview
The Microchip PIC32CX-BZ6 Series Device Family Pack (DFP) is a CMSIS-Pack that:
- Contains support files for the MPLAB XC32 Compiler.
- Contains support files for the GCC compiler.
- Contains support files for the Arm Compiler for Embedded.
- Contains support files for the IAR Embedded Development Tools.
- Flash algorithms for the on-chip flash memory.
Related packs
- pack: ARM::CMSISDevices
PIC32CX2051BZ62132
PIC32CX2051BZ66048
PIC32WM_BZ6204
PIC32WM_BZ6602
MISRA Compliance Deviations List
MISRA-C:2023
Deviation ID: MFWCG-40
- Rule 5.5: Identifiers shall be distinct from macro names.
- Use case: Identifiers corresponding to register names.
Example:
```c typedef union { struct { uint32_t GPIO:29; uint32_t :3; } vec; uint32_t reg; } ECIA_SRC8_Type;
#define GPIO (0x40081000) ```
- Reason: Access to hardware.
The macros expand into the same identifiers, which allow users to detect for the presence of specific registers during preprocessing.
- Scope: Device headers for the DEC15xx and MEC15xx family
<device-name>.h).
Deviation ID: MFWCG-42
- Rule 20.9: All identifiers used in the controlling expression of
#ifor#elifpreprocessing directives shall be#define'd before evaluation. - Use case: Use of compiler builtin macros.
Example:
c #ifdef (__ARM_FP == 14) || (__ARM_FP == 4) fpu_enable(); #endif- Reason: Access to hardware.
Headers may rely on builtin macros from the compiler and are written under the assumption that if the macro is not defined, its value is zero.
- Scope: All device headers (
<device-name>.h).
Deviation ID: MFWCG-43
- Rule 21.1:
#defineand#undefshall not be used on a reserved identifier or reserved macro name. - Use case: Reserved names, beginning with
_followed by a capital letter or__followed by a lower-case are within the compiler's namespace.
Example:
c #define __IO volatile- Reason: Access to hardware; Code Quality (Usability: Accessibility).
Within these headers originate many reserved names that are within the compiler's namespace.
<device-name>.h).
Deviation ID: MFWCG-44
- Rule 21.2: A reserved identifier or reserved macro name shall not be declared.
Example:
c extern const VECTOR_TABLE_Type __VECTOR_TABLE;- Reason: Access to hardware; Code Quality (Usability: Accessibility).
<device-name>.h).
MISRA-C:2025
- Rule 5.10: A reserved identifier or reserved macro name shall not be declared.
Example:
<device-name>.h).
Deviation ID: None
- Rule 11.4: A conversion shall not be performed between a pointer to object and an arithmetic type.
- Use case: Setting special registers from linker-generated symbols.
Example:
c pSrc = (uint32_t *) & __svectors; SCB->VTOR = ((uint32_t) pSrc & SCB_VTOR_TBLOFF_Msk);- Reason: Access to hardware.
Some hardware registers do not have a pointer type but hold an address.
- Scope: Device startup code (
startup_<name>.c)
Example:
<device-name>.h).
- Rule 20.15:
Example:
<device-name>.h).
MISRA-C:2023
Example:
```c #define WDTCON WDTCON extern volatile uint32_t WDTCON attribute((section("sfrs"), address(0xBF800000)));
#if defined(WDTCON) // Code that accesses WDTCON register #endif ```
<device-name>.h).
Deviation ID: MFWCG-41
- Rule 5.8: Identifiers that define objects or functions with external linkage shall be unique.
- Use case: Unions of bitfield structures that represent the implemented and semantic bits of the register.
Example:
c extern volatile uint32_t SYSKEY __attribute__((section("sfrs"), address(0xBF800030))); typedef struct { uint32_t SYSKEY:32; } __SYSKEYbits_t;- Reason: Access to hardware.
The names assigned are the same as those in the device data sheet. These are in direct correspondence to simplify code comprehension.
<device-name>.h).
Example:
c #if defined(__PIC32_HAS_MICROMIPS) // Conditional code for micromips #endif- Reason: Access to hardware.
<device-name>.h).
- Rule 21.1:
Example:
c #define _ICDSTAT _ICDSTAT- Reason: Access to hardware; Code Quality (Usability: Accessibility).
<device-name>.h).
Example:
c extern volatile uint32_t _ICDSTAT __attribute__((section("sfrs"), address(0xBF801010)));- Reason: Access to hardware; Code Quality (Usability: Accessibility).
<device-name>.h).
MISRA-C:2025
Example:
<device-name>.h).
Example:
<device-name>.h).
Example:
<device-name>.h).
- Rule 20.15:
Example:
<device-name>.h).
Support
