  1. Packs
  2. PIC32CM-LS_DFP
Overview
The Microchip PIC32CM-LS Series Device Family Pack (DFP) is a CMSIS-Pack that:
Related packs
    - pack: ARM::CMSIS
Devices
PIC32CM1216LS00032
PIC32CM LS00 family of devices based on Arm® Cortex®-M23 processor bring ultra-low power, superior touch, security and smart analog integration in one chip. They feature innovative low power techniques including SleepWalking peripherals, Arm TrustZone, immutable secure boot, industry leading water tolerant touch, Op Amps, Analog to Digital Converter (ADC) & Digital to Analog Converter (DAC). They are supported by MPLABX IDE, MPLAB Harmony v3 and MPLAB Code Configurator (MCC).
Documentation:
Application Notes:
Additional Documents:
PIC32CM1216LS00048
Documentation:
Application Notes:
PIC32CM2532LS00048
Documentation:
Application Notes:
PIC32CM2532LS00064
Documentation:
Application Notes:
PIC32CM2532LS00100
Documentation:
Application Notes:
PIC32CM5164LS00048
Documentation:
Application Notes:
PIC32CM5164LS00064
Documentation:
Application Notes:
PIC32CM5164LS00100
Documentation:
Application Notes:
PIC32CM5164LS60048
PIC32CM LS60 family of devices based on Arm® Cortex®-M23 processor bring hardened security, ultra-low power, superior touch, and smart analog integration in one package. They feature integrated Trust Platform ATECC608, Arm TrustZone, immutable secure boot, innovative low power techniques including SleepWalking peripherals, industry leading water tolerant touch, Op Amps, Analog to Digital Converter (ADC) & Digital to Analog Converter (DAC). They are supported by MPLABX IDE, MPLAB Harmony v3 and MPLAB Code Configurator (MCC).
Documentation:
Application Notes:
PIC32CM5164LS60064
Documentation:
Application Notes:
PIC32CM5164LS60100
Documentation:
Application Notes:
MISRA Compliance Deviations List
MISRA-C:2023
Deviation ID: MFWCG-40
  • Rule 5.5: Identifiers shall be distinct from macro names.
  • Use case: Identifiers corresponding to register names.
Example:
```C typedef union { struct { uint32_t GPIO:29; uint32_t :3; } vec; uint32_t reg; } ECIA_SRC8_Type;
#define GPIO (0x40081000) ```
  • Reason: Access to hardware.
The macros expand into the same identifiers, which allow users to detect for the presence of specific registers during preprocessing.
  • Scope: Device headers for the DEC15xx and MEC15xx family (<device-name>.h).
Deviation ID: MFWCG-42
  • Rule 20.9: All identifiers used in the controlling expression of #if or #elif preprocessing directives shall be #define'd before evaluation.
  • Use case: Use of compiler builtin macros.
Example:
C #ifdef (__ARM_FP == 14) || (__ARM_FP == 4) fpu_enable(); #endif
Headers may rely on builtin macros from the compiler and are written under the assumption that if the macro is not defined, its value is zero.
  • Scope: All device headers (<device-name>.h).
Deviation ID: MFWCG-43
  • Rule 21.1: #define and #undef shall not be used on a reserved identifier or reserved macro name.
  • Use case: Reserved names, beginning with _ followed by a capital letter or __ followed by a lower-case are within the compiler's namespace.
Example:
C #define __IO volatile
  • Reason: Access to hardware; Code Quality (Usability: Accessibility).
Within these headers originate many reserved names that are within the compiler's namespace.
Deviation ID: MFWCG-44
  • Rule 21.2: A reserved identifier or reserved macro name shall not be declared.
Example:
C extern const VECTOR_TABLE_Type __VECTOR_TABLE;
MISRA-C:2025
  • Rule 5.10: A reserved identifier or reserved macro name shall not be declared.
Example:
Deviation ID: None
  • Rule 11.4: A conversion shall not be performed between a pointer to object and an arithmetic type.
  • Use case: Setting special registers from linker-generated symbols.
Example:
C pSrc = (uint32_t *) & __svectors; SCB->VTOR = ((uint32_t) pSrc & SCB_VTOR_TBLOFF_Msk);
Some hardware registers do not have a pointer type but hold an address.
  • Scope: Device startup code (startup_<name>.c)
Example:
  • Rule 20.15: #define and #undef shall not be used on a reserved identifier or reserved macro name.
Example:
Support
