  1. Packs
  2. PIC32CK-SG_DFP
Overview
The Microchip PIC32CK-SG Series Device Family Pack (DFP) is a CMSIS-Pack that:
Related packs
    - pack: ARM::CMSIS
Devices
PIC32CK0512SG00064
PIC32CK0512SG00100
PIC32CK0512SG01064
PIC32CK0512SG01100
PIC32CK1012SG00048
PIC32CK1012SG00064
PIC32CK1012SG00100
PIC32CK1012SG01048
PIC32CK1012SG01064
PIC32CK1012SG01100
PIC32CK1025SG00064
PIC32CK1025SG00100
PIC32CK1025SG00144
PIC32CK1025SG01064
PIC32CK1025SG01100
PIC32CK1025SG01144
PIC32CK2051SG00064
PIC32CK2051SG00100
PIC32CK2051SG00144
PIC32CK2051SG01064
PIC32CK2051SG01100
PIC32CK2051SG01144
MISRA Compliance Deviations List
MISRA-C:2023
Deviation ID: MFWCG-40
  • Rule 5.5: Identifiers shall be distinct from macro names.
  • Use case: Identifiers corresponding to register names.
Example:
```c typedef union { struct { uint32_t GPIO:29; uint32_t :3; } vec; uint32_t reg; } ECIA_SRC8_Type;
#define GPIO (0x40081000) ```
  • Reason: Access to hardware.
The macros expand into the same identifiers, which allow users to detect for the presence of specific registers during preprocessing.
  • Scope: Device headers for the DEC15xx and MEC15xx family (<device-name>.h).
Deviation ID: MFWCG-42
  • Rule 20.9: All identifiers used in the controlling expression of #if or #elif preprocessing directives shall be #define'd before evaluation.
  • Use case: Use of compiler builtin macros.
Example:
c #ifdef (__ARM_FP == 14) || (__ARM_FP == 4) fpu_enable(); #endif
Headers may rely on builtin macros from the compiler and are written under the assumption that if the macro is not defined, its value is zero.
  • Scope: All device headers (<device-name>.h).
Deviation ID: MFWCG-43
  • Rule 21.1: #define and #undef shall not be used on a reserved identifier or reserved macro name.
  • Use case: Reserved names, beginning with _ followed by a capital letter or __ followed by a lower-case are within the compiler's namespace.
Example:
c #define __IO volatile
  • Reason: Access to hardware; Code Quality (Usability: Accessibility).
Within these headers originate many reserved names that are within the compiler's namespace.
Deviation ID: MFWCG-44
  • Rule 21.2: A reserved identifier or reserved macro name shall not be declared.
Example:
c extern const VECTOR_TABLE_Type __VECTOR_TABLE;
MISRA-C:2025
  • Rule 5.10: A reserved identifier or reserved macro name shall not be declared.
Example:
Deviation ID: None
  • Rule 11.4: A conversion shall not be performed between a pointer to object and an arithmetic type.
  • Use case: Setting special registers from linker-generated symbols.
Example:
c pSrc = (uint32_t *) & __svectors; SCB->VTOR = ((uint32_t) pSrc & SCB_VTOR_TBLOFF_Msk);
Some hardware registers do not have a pointer type but hold an address.
  • Scope: Device startup code (startup_<name>.c)
Example:
  • Rule 20.15: #define and #undef shall not be used on a reserved identifier or reserved macro name.
Example:
Support
