- Packs
- PIC32CK-SG_DFP
PIC32CK-SG_DFP
1.11.288-
Pack Type
Device Support
Microchip PIC32CK-SG Series Device Support
Add to CMSIS Solution
packs:- pack: Microchip::PIC32CK-SG_DFP@1.11.288
Add with cpackget
> cpackget add Microchip::PIC32CK-SG_DFP@1.11.288
Download
Microchip.PIC32CK-SG_DFP.1.11.288.packOverview
The Microchip PIC32CK-SG Series Device Family Pack (DFP) is a CMSIS-Pack that:
- Contains support files for the MPLAB XC32 Compiler.
- Contains support files for the GCC compiler.
- Contains support files for the Arm Compiler for Embedded.
- Contains support files for the IAR Embedded Development Tools.
- Flash algorithms for the on-chip flash memory.
Related packs
- pack: ARM::CMSISDevices
PIC32CK0512SG00064
PIC32CK0512SG00100
PIC32CK0512SG01064
PIC32CK0512SG01100
PIC32CK1012SG00048
PIC32CK1012SG00064
PIC32CK1012SG00100
PIC32CK1012SG01048
PIC32CK1012SG01064
PIC32CK1012SG01100
PIC32CK1025SG00064
PIC32CK1025SG00100
PIC32CK1025SG00144
PIC32CK1025SG01064
PIC32CK1025SG01100
PIC32CK1025SG01144
PIC32CK2051SG00064
PIC32CK2051SG00100
PIC32CK2051SG00144
PIC32CK2051SG01064
PIC32CK2051SG01100
PIC32CK2051SG01144
MISRA Compliance Deviations List
MISRA-C:2023
Deviation ID: MFWCG-40
- Rule 5.5: Identifiers shall be distinct from macro names.
- Use case: Identifiers corresponding to register names.
Example:
```c typedef union { struct { uint32_t GPIO:29; uint32_t :3; } vec; uint32_t reg; } ECIA_SRC8_Type;
#define GPIO (0x40081000) ```
- Reason: Access to hardware.
The macros expand into the same identifiers, which allow users to detect for the presence of specific registers during preprocessing.
- Scope: Device headers for the DEC15xx and MEC15xx family
<device-name>.h).
Deviation ID: MFWCG-42
- Rule 20.9: All identifiers used in the controlling expression of
#ifor#elifpreprocessing directives shall be#define'd before evaluation. - Use case: Use of compiler builtin macros.
Example:
c #ifdef (__ARM_FP == 14) || (__ARM_FP == 4) fpu_enable(); #endif- Reason: Access to hardware.
Headers may rely on builtin macros from the compiler and are written under the assumption that if the macro is not defined, its value is zero.
- Scope: All device headers (
<device-name>.h).
Deviation ID: MFWCG-43
- Rule 21.1:
#defineand#undefshall not be used on a reserved identifier or reserved macro name. - Use case: Reserved names, beginning with
_followed by a capital letter or__followed by a lower-case are within the compiler's namespace.
Example:
c #define __IO volatile- Reason: Access to hardware; Code Quality (Usability: Accessibility).
Within these headers originate many reserved names that are within the compiler's namespace.
<device-name>.h).
Deviation ID: MFWCG-44
- Rule 21.2: A reserved identifier or reserved macro name shall not be declared.
Example:
c extern const VECTOR_TABLE_Type __VECTOR_TABLE;- Reason: Access to hardware; Code Quality (Usability: Accessibility).
<device-name>.h).
MISRA-C:2025
- Rule 5.10: A reserved identifier or reserved macro name shall not be declared.
Example:
<device-name>.h).
Deviation ID: None
- Rule 11.4: A conversion shall not be performed between a pointer to object and an arithmetic type.
- Use case: Setting special registers from linker-generated symbols.
Example:
c pSrc = (uint32_t *) & __svectors; SCB->VTOR = ((uint32_t) pSrc & SCB_VTOR_TBLOFF_Msk);- Reason: Access to hardware.
Some hardware registers do not have a pointer type but hold an address.
- Scope: Device startup code (
startup_<name>.c)
Example:
<device-name>.h).
- Rule 20.15:
Example:
<device-name>.h).
Support
