  1. Packs
  2. PIC32CX-BZ3_DFP
Overview
The Microchip PIC32CX-BZ3 Series Device Family Pack (DFP) is a CMSIS-Pack that:
Related packs
    - pack: ARM::CMSIS
Devices
PIC32CX5109BZ31032
Part of the PIC32CX-BZ family, PIC32CX5109BZ31032 is a secure, low-cost 32-bit microcontroller with an inbuilt wireless subsystem certified for Bluetooth® and Zigbee®. Designed from the ground up to enable you to go to market quickly, PIC32CX5109BZ31032 is powered by a 64 MHz ARM® Cortex® M4F and is packed with features.---Ultra-low power 2.4 GHz transceiver: Build applications enabling Bluetooth Low-Energy (LE) 6.0, IEEE® 802.15.4 / Zigbee 3.0 connectivity with hardware-level arbitration for multi-protocol wireless functionality.Hardware-based security (secure boot): Protect applications with NIST-compliant authentication and secure boot ROM to ensure only trusted software runs on your system. Robust analog peripherals: Industrial-grade capacitive touch, ADCs, DAC and comparators enable versatile sensor integration and analog management for a wide range of applications.Functional safety: This device supports the ISO 26262 (ASIL B), and IEC 61508 (SIL 2) functional safety standards. The Functional Safety Manual, FMEDA and Diagnostic Software information are available under NDA. Contact us for more information.
Documentation:
Application Notes:
Additional Documents:
PIC32CX5109BZ31032_SL3
PIC32CX5109BZ31048
Part of the PIC32CX-BZ family, PIC32CX5109BZ31048 is a secure, low-cost 32-bit microcontroller with an inbuilt wireless subsystem certified for Bluetooth® and Zigbee®. Designed from the ground up to enable you to go to market quickly, PIC32CX5109BZ31048 is powered by a 64 MHz ARM® Cortex® M4F and is packed with features.---Ultra-low power 2.4 GHz transceiver: Build applications enabling Bluetooth Low-Energy (LE) 6.0, IEEE® 802.15.4 / Zigbee 3.0 connectivity with hardware-level arbitration for multi-protocol wireless functionality.Hardware-based security (secure boot): Protect applications with NIST-compliant authentication and secure boot ROM to ensure only trusted software runs on your system. Robust analog peripherals: Industrial-grade capacitive touch, ADCs, DAC and comparators enable versatile sensor integration and analog management for a wide range of applications.Functional safety: This device supports the ISO 26262 (ASIL B), and IEC 61508 (SIL 2) functional safety standards. The Functional Safety Manual, FMEDA and Diagnostic Software information are available under NDA. Contact us for more information.
Documentation:
Application Notes:
PIC32CX5109BZ31048_SL3
PIC32CX5109BZ36032
Part of the PIC32CX-BZ family, PIC32CX5109BZ36032 is a secure, low-cost 32-bit microcontroller with an inbuilt wireless subsystem certified for Bluetooth® and Zigbee®. Building on the foundation of the PIC32CX-BZ3, the PIC32CX-BZ36 introduces a new low-power operating mode to further reduce consumption and an enhanced secure boot process for added protection.Designed from the ground up to enable you to go to market quickly, PIC32CX5109BZ36032 is powered by a 64 MHz ARM® Cortex® M4F and is packed with features.---Ultra-low power 2.4 GHz transceiver: Build applications enabling Bluetooth Low-Energy (LE) 6.0, IEEE® 802.15.4 / Zigbee 3.0 connectivity with hardware-level arbitration for multi-protocol wireless functionality.Buck (DC-DC/switching) mode: Supports high power (PWM) and low power (PSM) mode, providing efficient power management for a wide range of operating conditions.Hardware-based security (secure boot): Protect applications with NIST-compliant authentication and secure boot ROM to ensure only trusted software runs on your system. Robust analog peripherals: Industrial-grade capacitive touch, ADCs, DAC and comparators enable versatile sensor integration and analog management for a wide range of applications.Functional safety: This device supports the ISO 26262 (ASIL B), and IEC 61508 (SIL 2) functional safety standards. The Functional Safety Manual, FMEDA and Diagnostic Software information are available under NDA. Contact us for more information.---Ultra-low power 2.4 GHz transceiver: Build applications enabling Bluetooth Low-Energy (LE) 6.0, IEEE® 802.15.4 / Zigbee 3.0 connectivity with hardware-level arbitration for multi-protocol wireless functionality.Buck (DC-DC/switching) mode: Supports high power (PWM) and low power (PSM) mode, providing efficient power management for a wide range of operating conditions.Hardware-based security (secure boot): Protect applications with NIST-compliant authentication and secure boot ROM to ensure only trusted software runs on your system. Robust analog peripherals: Industrial-grade capacitive touch, ADCs, DAC and comparators enable versatile sensor integration and analog management for a wide range of applications.Functional safety: This device supports the ISO 26262 (ASIL B), and IEC 61508 (SIL 2) functional safety standards. The Functional Safety Manual, FMEDA and Diagnostic Software information are available under NDA. Contact us for more information.
Documentation:
Application Notes:
PIC32CX5109BZ36032_SL3
PIC32CX5109BZ36048
Part of the PIC32CX-BZ family, PIC32CX5109BZ36048 is a secure, low-cost 32-bit microcontroller with an inbuilt wireless subsystem certified for Bluetooth® and Zigbee®. Building on the foundation of the PIC32CX-BZ3, the PIC32CX-BZ36 introduces a new low-power operating mode to further reduce consumption and an enhanced secure boot process for added protection.Designed from the ground up to enable you to go to market quickly, PIC32CX5109BZ36048 is powered by a 64 MHz ARM® Cortex® M4F and is packed with features.---Ultra-low power 2.4 GHz transceiver: Build applications enabling Bluetooth Low-Energy (LE) 6.0, IEEE® 802.15.4 / Zigbee 3.0 connectivity with hardware-level arbitration for multi-protocol wireless functionality.Buck (DC-DC/switching) mode: Supports high power (PWM) and low power (PSM) mode, providing efficient power management for a wide range of operating conditions.Hardware-based security (secure boot): Protect applications with NIST-compliant authentication and secure boot ROM to ensure only trusted software runs on your system. Robust analog peripherals: Industrial-grade capacitive touch, ADCs, DAC and comparators enable versatile sensor integration and analog management for a wide range of applications.Functional safety: This device supports the ISO 26262 (ASIL B), and IEC 61508 (SIL 2) functional safety standards. The Functional Safety Manual, FMEDA and Diagnostic Software information are available under NDA. Contact us for more information.
Documentation:
Application Notes:
PIC32CX5109BZ36048_SL3
PIC32WM_BZ3601
PIC32WM_BZ3601_SL3
PIC32WM_BZ3602
PIC32WM_BZ3602_SL3
WBZ350
WBZ350_SL3
WBZ351
WBZ351_SL3
MISRA-C:2023 Compliance Deviations List
Deviation ID: MFWCG-40
  • Rule 5.5: Identifiers shall be distinct from macro names.
  • Use case: Identifiers corresponding to register names.
Example:
```C typedef union { struct { uint32_t GPIO:29; uint32_t :3; } vec; uint32_t reg; } ECIA_SRC8_Type;
#define GPIO (0x40081000) ```
  • Reason: Access to hardware.
The macros expand into the same identifiers, which allow users to detect for the presence of specific registers during preprocessing.
  • Scope: Device headers for the DEC15xx and MEC15xx family (<device-name>.h).
Deviation ID: MFWCG-42
  • Rule 20.9: All identifiers used in the controlling expression of #if or #elif preprocessing directives shall be #define'd before evaluation.
  • Use case: Use of compiler builtin macros.
Example:
C #ifdef (__ARM_FP == 14) || (__ARM_FP == 4) fpu_enable(); #endif
Headers may rely on builtin macros from the compiler and are written under the assumption that if the macro is not defined, its value is zero.
  • Scope: All device headers (<device-name>.h).
Deviation ID: MFWCG-43
  • Rule 21.1: #define and #undef shall not be used on a reserved identifier or reserved macro name.
  • Use case: Reserved names, beginning with _ followed by a capital letter or __ followed by a lower-case are within the compiler's namespace.
Example:
C #define __IO volatile
  • Reason: Access to hardware; Code Quality (Usability: Accessibility).
Within these headers originate many reserved names that are within the compiler's namespace.
Deviation ID: MFWCG-44
  • Rule 21.2: A reserved identifier or reserved macro name shall not be declared.
Example:
C extern const VECTOR_TABLE_Type __VECTOR_TABLE;
Example:
```C #define WDTCON WDTCON extern volatile uint32_t WDTCON attribute((section("sfrs"), address(0xBF800000)));
#if defined(WDTCON) // Code that accesses WDTCON register #endif ```
Deviation ID: MFWCG-41
  • Rule 5.8: Identifiers that define objects or functions with external linkage shall be unique.
  • Use case: Unions of bitfield structures that represent the implemented and semantic bits of the register.
Example:
C extern volatile uint32_t SYSKEY __attribute__((section("sfrs"), address(0xBF800030))); typedef struct { uint32_t SYSKEY:32; } __SYSKEYbits_t;
The names assigned are the same as those in the device data sheet. These are in direct correspondence to simplify code comprehension.
Example:
C #if defined(__PIC32_HAS_MICROMIPS) // Conditional code for micromips #endif
Example:
C #define _ICDSTAT _ICDSTAT
Example:
C extern volatile uint32_t _ICDSTAT __attribute__((section("sfrs"), address(0xBF801010)));
Support
