- Packs
- PIC32CM-LE_DFP
PIC32CM-LE_DFP
1.4.336-
Pack Type
Device Support
Microchip PIC32CM-LE Series Device Support
Add to CMSIS Solution
packs:- pack: Microchip::PIC32CM-LE_DFP@1.4.336
Add with cpackget
> cpackget add Microchip::PIC32CM-LE_DFP@1.4.336
Download
Microchip.PIC32CM-LE_DFP.1.4.336.packOverview
The Microchip PIC32CM-LE Series Device Family Pack (DFP) is a CMSIS-Pack that:
- Contains support files for the MPLAB XC32 Compiler.
- Contains support files for the GCC compiler.
- Contains support files for the Arm Compiler for Embedded.
- Contains support files for the IAR Embedded Development Tools.
- Flash algorithms for the on-chip flash memory.
Related packs
- pack: ARM::CMSISDevices
PIC32CM1216LE00032
PIC32CM LE00 family of devices based on Arm® Cortex®-M23 processor bring ultra-low power, superior touch, and smart analog integration in one chip. They feature innovative low power techniques including SleepWalking peripherals, industry leading water tolerant touch, Op Amps, Analog to Digital Converter (ADC) & Digital to Analog Converter (DAC). They are supported by MPLABX IDE, MPLAB Harmony v3 and MPLAB Code Configurator (MCC).
Documentation:
Application Notes:
- AN4068 - PIC32CM LE00/LS00/LS60 Low-Power Features
- SERCOM USART on Microchip Cortex Devices (SAM and PIC32C)
Additional Documents:
- Atmel START to MPLAB Harmony v3 Migration Guide
- MPLAB Harmony Overview
- MPLAB Harmony v3 Synchronous Drivers and Their Usage in FreeRTOS-Based Applications
- MPLAB XC32 C/C++ Compiler User's Guide for PIC32C/SAM MCUs
PIC32CM1216LE00048
Documentation:
Application Notes:
PIC32CM2532LE00048
Documentation:
Application Notes:
- AN4511 - Getting Started with the PIC32CM LE00/LS00/LS60 Curiosity Pro Board
- How to Setup MPLAB Harmony v3 Software Development Framework
- 32-bit Microcontroller Collateral and Solutions Reference Guide
PIC32CM2532LE00064
Documentation:
Application Notes:
- The Differences Between MPLAB Harmony v3 Synchronous and Asynchronous Drivers and When to Use Them
- 32-bit Quick Reference Guide
PIC32CM2532LE00100
Documentation:
Application Notes:
PIC32CM5164LE00048
Documentation:
Application Notes:
PIC32CM5164LE00064
Documentation:
Application Notes:
- Introduction to MPLAB Harmony v3 for Atmel Studio and ASF Users
PIC32CM5164LE00100
Documentation:
Application Notes:
Videos
- https://www.youtube.com/watch?v=tigCfhOmqmc
MISRA-C:2023 Compliance Deviations List
Deviation ID: MFWCG-40
- Rule 5.5: Identifiers shall be distinct from macro names.
- Use case: Identifiers corresponding to register names.
Example:
```C typedef union { struct { uint32_t GPIO:29; uint32_t :3; } vec; uint32_t reg; } ECIA_SRC8_Type;
#define GPIO (0x40081000) ```
- Reason: Access to hardware.
The macros expand into the same identifiers, which allow users to detect for the presence of specific registers during preprocessing.
- Scope: Device headers for the DEC15xx and MEC15xx family
<device-name>.h).
Deviation ID: MFWCG-42
- Rule 20.9: All identifiers used in the controlling expression of
#ifor#elifpreprocessing directives shall be#define'd before evaluation. - Use case: Use of compiler builtin macros.
Example:
C #ifdef (__ARM_FP == 14) || (__ARM_FP == 4) fpu_enable(); #endif- Reason: Access to hardware.
Headers may rely on builtin macros from the compiler and are written under the assumption that if the macro is not defined, its value is zero.
- Scope: All device headers (
<device-name>.h).
Deviation ID: MFWCG-43
- Rule 21.1:
#defineand#undefshall not be used on a reserved identifier or reserved macro name. - Use case: Reserved names, beginning with
_followed by a capital letter or__followed by a lower-case are within the compiler's namespace.
Example:
C #define __IO volatile- Reason: Access to hardware; Code Quality (Usability: Accessibility).
Within these headers originate many reserved names that are within the compiler's namespace.
<device-name>.h).
Deviation ID: MFWCG-44
- Rule 21.2: A reserved identifier or reserved macro name shall not be declared.
Example:
C extern const VECTOR_TABLE_Type __VECTOR_TABLE;- Reason: Access to hardware; Code Quality (Usability: Accessibility).
<device-name>.h).
Support
