- Packs
- PIC32CK-GC_DFP
PIC32CK-GC_DFP
1.5.239-
Pack Type
Device Support
Microchip PIC32CK-GC Series Device Support
Add to CMSIS Solution
packs:- pack: Microchip::PIC32CK-GC_DFP@1.5.239
Add with cpackget
> cpackget add Microchip::PIC32CK-GC_DFP@1.5.239
Download
Microchip.PIC32CK-GC_DFP.1.5.239.packOverview
The Microchip PIC32CK-GC Series Device Family Pack (DFP) is a CMSIS-Pack that:
- Contains support files for the MPLAB XC32 Compiler.
- Contains support files for the GCC compiler.
- Contains support files for the Arm Compiler for Embedded.
- Contains support files for the IAR Embedded Development Tools.
- Flash algorithms for the on-chip flash memory.
Related packs
- pack: ARM::CMSISDevices
PIC32CK0512GC00064
PIC32CK0512GC00100
PIC32CK0512GC01064
PIC32CK0512GC01100
PIC32CK1012GC00048
PIC32CK1012GC00064
PIC32CK1012GC00100
PIC32CK1012GC01048
PIC32CK1012GC01064
PIC32CK1012GC01100
PIC32CK1025GC00064
PIC32CK1025GC00100
PIC32CK1025GC01064
Arm® Cortex®-M33 Based 120 MHz MCUs with Connectivity PeripheralsThe PIC32CK SG/GC family of microcontrollers (MCUs) is based on Arm® Cortex®-M33 technology. The M33 is optimized for power-sensitive microcontroller and mixed-signal applications. It improves performance over the previous generation, real-time determinism, energy efficiency, software productivity, and system security. The PIC32CK SG/GC family offers a large memory capacity with 2 MB of Dual Panel Flash and 512 KB of SRAM.The SG variants are intended for highly secure connectivity and applications needing the most secure key management and cryptographic operations. The SG family combines an on-chip, fully isolated Hardware Security Module (HSM) with Arm TrustZone® technology. The GC variants are intended for general-purpose mixed-signal applications that do not need the HSM and advanced security features.The PIC32CK SG/GC devices have connectivity options including standard serial communications (UART, USART, SPI, I2C, etc.,) I2S, USB, CAN FD, and 10/100 Ethernet. Advanced analog includes a 12-bit 3 Msps ADC and Peripheral Touch Controller.The PIC32CK SG/GC is fully supported by MPLAB X IDE and MPLAB® Harmony Integrated Design Environment. CAN FD and 10/100 Ethernet IEEE1588. These MCUs are available in 144-pin and 100-pin, 64-pin package options.
Documentation:
Application Notes:
- Migration Guide from SAM D5x/E5x to PIC32CK SG01/SG00/GC01/GC00
- SERCOM USART on Microchip Cortex Devices (SAM and PIC32C)
Additional Documents:
- PIC32CK SG01/GC01 Family Silicon Errata and Data Sheet Clarifications
- 32-bit MCU Brochure
- PIC32CK SG01/GC01 Curiosity Ultra User's Guide
- Creating the First Application on PIC32CK GC Microcontrollers Using MPLAB Harmony v3 with MPLAB Code Configurator (MCC)
- How to Setup MPLAB Harmony v3 Software Development Framework
- 32-bit Microcontroller Collateral and Solutions Reference Guide
PIC32CK1025GC01100
Documentation:
Application Notes:
PIC32CK1025GC01144
Documentation:
Application Notes:
PIC32CK2051GC00064
PIC32CK2051GC00100
PIC32CK2051GC00144
PIC32CK2051GC01064
Documentation:
Application Notes:
PIC32CK2051GC01100
Documentation:
Application Notes:
PIC32CK2051GC01144
Arm® Cortex®-M33 120 MHz MCUs with Connectivity PeripheralsThe PIC32CK SG/GC family of microcontrollers (MCUs) is based on Arm® Cortex®-M33 technology. The M33 is optimized for power-sensitive microcontroller and mixed-signal applications. It improves performance over the previous generation, real-time determinism, energy efficiency, software productivity, and system security. The PIC32CK SG/GC family offers a large memory capacity with 2 MB of Dual Panel Flash and 512 KB of SRAM.The SG variants are intended for highly secure connectivity and applications needing the most secure key management and cryptographic operations. The SG family combines an on-chip, fully isolated Hardware Security Module (HSM) with Arm TrustZone® technology. The GC variants are intended for general-purpose mixed-signal applications that do not need the HSM and advanced security features.The PIC32CK SG/GC devices have connectivity options including standard serial communications (UART, USART, SPI, I2C, etc.,) I2S, USB, CAN FD, and 10/100 Ethernet. Advanced analog includes a 12-bit 3 Msps ADC and Peripheral Touch Controller.The PIC32CK SG/GC is fully supported by MPLAB X IDE and MPLAB® Harmony Integrated Design Environment. CAN FD and 10/100 Ethernet IEEE1588. These MCUs are available in 144-pin and 100-pin, 64-pin package options.
Documentation:
Application Notes:
MISRA Compliance Deviations List
MISRA-C:2023
Deviation ID: MFWCG-40
- Rule 5.5: Identifiers shall be distinct from macro names.
- Use case: Identifiers corresponding to register names.
Example:
```c typedef union { struct { uint32_t GPIO:29; uint32_t :3; } vec; uint32_t reg; } ECIA_SRC8_Type;
#define GPIO (0x40081000) ```
- Reason: Access to hardware.
The macros expand into the same identifiers, which allow users to detect for the presence of specific registers during preprocessing.
- Scope: Device headers for the DEC15xx and MEC15xx family
<device-name>.h).
Deviation ID: MFWCG-42
- Rule 20.9: All identifiers used in the controlling expression of
#ifor#elifpreprocessing directives shall be#define'd before evaluation. - Use case: Use of compiler builtin macros.
Example:
c #ifdef (__ARM_FP == 14) || (__ARM_FP == 4) fpu_enable(); #endif- Reason: Access to hardware.
Headers may rely on builtin macros from the compiler and are written under the assumption that if the macro is not defined, its value is zero.
- Scope: All device headers (
<device-name>.h).
Deviation ID: MFWCG-43
- Rule 21.1:
#defineand#undefshall not be used on a reserved identifier or reserved macro name. - Use case: Reserved names, beginning with
_followed by a capital letter or__followed by a lower-case are within the compiler's namespace.
Example:
c #define __IO volatile- Reason: Access to hardware; Code Quality (Usability: Accessibility).
Within these headers originate many reserved names that are within the compiler's namespace.
<device-name>.h).
Deviation ID: MFWCG-44
- Rule 21.2: A reserved identifier or reserved macro name shall not be declared.
Example:
c extern const VECTOR_TABLE_Type __VECTOR_TABLE;- Reason: Access to hardware; Code Quality (Usability: Accessibility).
<device-name>.h).
MISRA-C:2025
- Rule 5.10: A reserved identifier or reserved macro name shall not be declared.
Example:
<device-name>.h).
Deviation ID: None
- Rule 11.4: A conversion shall not be performed between a pointer to object and an arithmetic type.
- Use case: Setting special registers from linker-generated symbols.
Example:
c pSrc = (uint32_t *) & __svectors; SCB->VTOR = ((uint32_t) pSrc & SCB_VTOR_TBLOFF_Msk);- Reason: Access to hardware.
Some hardware registers do not have a pointer type but hold an address.
- Scope: Device startup code (
startup_<name>.c)
Example:
<device-name>.h).
- Rule 20.15:
Example:
<device-name>.h).
Support
