- Packs
- MicroBit_V2_BSP
MicroBit_V2_BSP
0.2.0-
Pack Type
Board Support
BBC micro:bit V2 Board Support Pack (Nordic nRF52833)
Add to CMSIS Solution
packs:- pack: MicroBit::MicroBit_V2_BSP@0.2.0
Add with cpackget
> cpackget add MicroBit::MicroBit_V2_BSP@0.2.0
Download
MicroBit.MicroBit_V2_BSP.0.2.0.packRepository
MicroBit_V2_BSPMicroBit_V2_BSP
The BBC micro:bit V2 Board Support Pack (BSP):
- Describes the board (mounted Nordic nRF52833, on-board DAPLink debug probe, features) so that it can be
selected as
MicroBit::microbit-v2in csolution projects. - Provides a CMSIS-Driver VIO implementation for the LED matrix and the buttons A and B.
- Provides Board Support drivers for every on-board peripheral: LED matrix, buttons, touch logo, speaker, microphone, LSM303AGR motion sensor, UART to the DAPLink interface (USB serial), die temperature, SysTick time base.
- Contains the examples Blinky and BoardTest in csolution format for the CMSIS-Toolbox and the VS Code Arm CMSIS Solution extension.
- Ships the board schematic (CC BY-SA 4.0) and links the datasheets of the nRF52833, LSM303AGR and microphone.
- Contains knowledge units for the CMSIS Developer Assistant in
.knowledge/. - Requires the Device Family Pack
NordicSemiconductor::nRF_DeviceFamilyPack(device header, startup and system files, SVD, flash algorithms for the nRF52833) andARM::CMSIS.
Content
Directory / File Content Boardvio_microbit_v2.cCMSIS-Driver VIO;microbit_*.cBoard Support driversBoard/Includemicrobit_v2.h: pin map and API of all Board Support componentsExamples/BlinkyBlinky example (csolution), GCC linker script for the Nordic startup file Examples/BoardTestExercises all peripherals with serial output and single-key commands DocumentsThis overview, MicroBit_V2.2.1_nRF52820_schematic.pdfand its attributionMicroBit_V2.2.1_nRF52820_schematic.ATTRIBUTION.md.knowledgeKnowledge units (troubleshooting, concepts, procedures) for the CMSIS Developer Assistant Software components
Component Description CMSIS Driver:VIO:BoardVirtual I/O: vioLED0..4 on LED matrix row 1, vioBUTTON0..1 on buttons A and B (not with Board Support:LED Matrix)Board Support:GPIOPin map ( MB_PIN_*), GPIO helpers, microsecond busy delay; required by the other Board Support componentsBoard Support:TimeSysTick millisecond time base: microbit_time_init,microbit_time_ms,microbit_delay_msBoard Support:UARTUARTE0 to the DAPLink USB serial (TX P0.06, RX P1.08): microbit_uart_init/putc/write/getcBoard Support:I2CInternal I2C bus TWIM0 at 400 kHz: microbit_i2c_write/read/write_read/read_reg/write_regBoard Support:Motion SensorLSM303AGR: microbit_motion_init,microbit_accel_read(mg),microbit_mag_read(mgauss)Board Support:LED Matrix5x5 matrix with TIMER1 refresh: pixels, images, 5x5 font ( microbit_display_*)Board Support:Buttonsmicrobit_button_pressed(MICROBIT_BUTTON_A/B)Board Support:TouchCapacitive logo: microbit_touch_init,microbit_touch_logo_pressed, raw charge timeBoard Support:SpeakerPWM0 tones: microbit_speaker_tone(hz),microbit_speaker_offBoard Support:MicrophoneSAADC on AIN3, RUN_MIC power: microbit_mic_sample,microbit_mic_levelBoard Support:TemperaturenRF52833 die sensor: microbit_temperature_readin 0.25 C unitsAll Board Support components share the header
microbit_v2.h. Standard I/O: use CMSIS-CompilerSTDOUT:Customwithstdout_putcharcallingmicrobit_uart_putc(seeExamples/BoardTest/retarget_stdio.c).Board
Property Value Board MicroBit::microbit-v2(revision V2.2; V2.0 boards differ only in the interface MCU)Device Nordic Semiconductor::nRF52833_xxAA(Cortex-M4F, 64 MHz, 512 KB Flash, 128 KB RAM)Debug probe On-board DAPLink (CMSIS-DAP, SWD) over USB micro-B Programming CMSIS-DAP or drag-and-drop of a .hexfile to theMICROBITdrivePin mapping
Function nRF52833 pin LED matrix ROW1..5 P0.21, P0.22, P0.15, P0.24, P0.19 (LED on: row high, column low) LED matrix COL1..5 P0.28, P0.11, P0.31, P1.05, P0.30 Button A / B P0.14 / P0.23 (active low, 10 kOhm pull-ups on the board) UART to DAPLink TX P0.06, RX P1.08 (USB serial on the host, 115200 8N1 in the examples) Internal I2C SCL P0.08, SDA P0.16, INT P0.25 (LSM303AGR 0x19/0x1E, interface MCU; 1 kOhm pull-ups) External I2C SCL P0.26 (P19), SDA P1.00 (P20); 4.7 kOhm pull-ups External SPI SCK P0.17 (P13), MISO P0.01 (P14), MOSI P0.13 (P15) Speaker P0.00 (MLT-8530 through a MOSFET) Microphone MIC_IN P0.05 / AIN3, RUN_MIC P0.20 (power, also lights the microphone LED) Touch logo P1.04 (10 MOhm pull-up on the board) Edge connector P0 P0.02, P1 P0.03, P2 P0.04, P8 P0.10, P9 P0.09, P12 P0.12, P16 P1.02; others shared as above On-board parts (schematic V2.2.1): nRF52833-QIAA target, nRF52820-QDAA interface MCU (DAPLink; KL27Z on V2.0), LSM303AGRTR, Knowles SPU0410LR5H-QB-7 analog microphone, MLT-8530 speaker, onsemi NCP114 3.3 V regulator.
Sources:
Documents/MicroBit_V2.2.1_nRF52820_schematic.pdf(Micro:bit Educational Foundation, CC BY-SA 4.0), micro:bit V2 schematic and pin map, edge connector.Notes on the Nordic DFP
The Nordic
nRF_DeviceFamilyPack(8.44.1) predates the CMSIS-Toolbox. Its startup files are assembler files (gcc_startup_nrf52833.S,arm_startup_nrf52833.s) and the pack ships no linker script that the toolbox can use directly. The GCC startup places the vector table in a section named.isr_vector, which the toolbox linker script template does not keep at the start of Flash. The Blinky example therefore carries a copy of the template withKEEP(*(.isr_vector))added; copyExamples/Blinky/RTE/Device/nRF52833_xxAA/into your own project when you build with GCC. The Arm Compiler 6 startup file uses theRESETarea and works with the toolbox scatter template.The DFP selects Nordic's standard flash algorithm
nrf52xxx.flm. It refuses to erase sectors that hold a Nordic SoftDevice, which the factory firmware of the micro:bit contains. The first download to a factory-programmed board therefore fails under pyOCD; program the board once by drag-and-drop of a.hexfile to theMICROBITdrive, then pyOCD download and debug work (see the Blinky README).Validation
Blinky and BoardTest were built with GCC 14.3.1 and CMSIS-Toolbox 2.15.0, downloaded with pyOCD 0.45.1 (CMSIS-DAP@pyOCD) and debugged on a micro:bit V2.2 (DAPLink 0257): vector table at Flash address 0, FICR reports nRF52833 (512 KB Flash, 128 KB RAM), breakpoints in
mainandvioInithit, LED matrix rows and columns driven as documented, SysTick at 1 ms, UART at 115200 in both directions, LSM303AGR identified and read (acceleration magnitude 1.02 g, magnetic field 0.5 to 0.75 gauss in the air), die temperature about 21 C, buttons and touch logo (charge time 194 counts untouched, 4500 to 40000 touched), microphone bias 73 mV.
