- Packs
- ExecuTorch
ExecuTorch
1.5.1-
Pack Type
Software Pack
ExecuTorch: PyTorch Edge Runtime for on-device AI inference on Arm Cortex-M processors.
Add to CMSIS Solution
packs:- pack: PyTorch::ExecuTorch@1.5.1
Add with cpackget
> cpackget add PyTorch::ExecuTorch@1.5.1
Download
PyTorch.ExecuTorch.1.5.1.packRepository
ExecuTorchExecuTorch CMSIS Pack
Overview
ExecuTorch is the PyTorch Edge Runtime, enabling efficient on-device AI inference. This pack is the Cortex-M / bare-metal distribution.
This pack provides: - Core Runtime: Program loading and execution - Portable Operators: Platform-independent operator implementations - Quantized Operators: Optimized quantized inference - Ethos-U Backend: Hardware acceleration for Arm Ethos-U NPU - Cortex-M Backend: CMSIS-NN optimized operators
Getting Started
Basic Usage
Add the pack to your csolution: ```yaml packs:
- pack: PyTorch::ExecuTorch ```
Add required components: ```yaml components: # Core runtime (always required)
- component: Machine Learning:ExecuTorch:Runtime
- component: Machine Learning:ExecuTorch:Kernel Utils
# Backend (choose one or more). CMSIS component IDs use a single # colon between Cclass / Cgroup / Csub, with a space (not "::") # inside the Csub name. - component: Machine Learning:ExecuTorch:Backend EthosU # or - component: Machine Learning:ExecuTorch:Backend CortexM ```
Include ExecuTorch headers in your code:
cpp #include <executorch/runtime/executor/program.h> #include <executorch/runtime/executor/method.h>
Model Integration
Operators are included as individual CMSIS components, one per
op_*.cpp. Add the ones your model uses:components: - component: Machine Learning:ExecuTorch Operators:Portable add - component: Machine Learning:ExecuTorch Operators:Portable mul # ... other operators used by your modelYou can also generate this list automatically: a Model Pack produced from your
.ptefile declares dependencies on the operators the model needs, and the toolchain resolves them against this pack's components.Renamed Components
The CMSIS-Pack schema limits component names to 32 characters. Since pack version 1.4.1 three operator components therefore carry shortened names; projects written against the 1.4.0 pack must update them:
Up to 1.4.0 From 1.4.1 Portable max_pool2d_with_indices_backwardPortable max_pool2d_indices_bwdCortex-M quantized_depthwise_conv2dCortex-M quantized_dw_conv2dCortex-M quantized_transpose_conv2dCortex-M quantized_tr_conv2dMemory Requirements
Component Flash (approx) RAM (approx) Runtime 50-100 KB 4-8 KB Per Operator 1-10 KB minimal Ethos-U Backend 20-40 KB 2-4 KB Actual requirements depend on: - Selected operators - Model complexity - Tensor sizes
Compiler Support
Tested with
arm-none-eabi-gcc14.3 and Arm Compiler for Embedded (AC6) 6.23 on Cortex-M85. LLVM Embedded Toolchain for Arm is expected to work but was not exercised for this release.AC6 projects must build with
-ffp-mode=full. armclang otherwise assumes finite math, which breaks operators that depend on IEEE inf/NaN behaviour (isinf,isnan,gelu).Dependencies
- ARM::CMSIS (core headers)
- ARM::CMSIS-NN (for Cortex-M backend)
- ARM::ethos-u-core-driver (for Ethos-U backend)
CMSIS-NN 8.0.0 on Cortex-M55 and Cortex-M85
The
ARM::CMSIS-NN8.0.0 pack does not compile in its default configuration for cores with Helium floating-point support (MVE-F), such as Cortex-M55 and Cortex-M85. Four of its element-wise sources fail withimplicit declaration of function 'arm_nn_clamp_mve_f32'(or..._f16).Until a fixed CMSIS-NN release is available, enable CMSIS-NN's float support in any project that selects the Cortex-M operators on such a core:
# in the *.csolution.yml or *.cproject.yml define: - ARM_NN_ENABLE_F32: 1 - ARM_NN_ENABLE_F16: 1Resources
