- Packs
- Ensemble
Ensemble
2.0.4-
Pack Type
Board Support
Device Support
Alif Semiconductor Ensemble Device Family Pack
Add to CMSIS Solution
packs:- pack: AlifSemiconductor::Ensemble@2.0.4
Add with cpackget
> cpackget add AlifSemiconductor::Ensemble@2.0.4
Download
AlifSemiconductor.Ensemble.2.0.4.packPack Content
The
Alif Semiconductor Ensemble Device Family Packcontains Device and Board support for:- Alif Semiconductor Ensemble E1C/E1/E3/E5/E7/E8 AI/ML microcontroller series with up two Arm Cortex-M55 and two Arm Ethos-U55 microNPUs.
- Alif Semiconductor Ensemble E7 DevKit - Gen 2 single board computer with access to all signals and pins for power/performance profiling.
- Alif Semiconductor Ensemble E7 AI/ML AppKit - Gen 2 single board computer with camera/image, motion, sound sensors and display.
This Pack contains:
- Support for Arm Compiler 6 (AC6) and GCC.
- Debug configuration information and SVD files for peripheral awareness.
- SoC Peripheral interfaces and CMSIS-Driver for CAN, GPIO, I2C, SAI, SPI, USART.
- Template and example projects for uVision IDE and CMSIS-Toolbox (VS Code).
Device Support (DFP)
The device is configured using the Alif Semiconductor Conductor Tool. The secure enclave of the device is configured using the Alif Secure Toolkit (SETOOLS) that generates and downloads an Application Table of Content (ATOC) for the device.
NOTE
Before downloading examples it is required to program the ATOC to the device. Usage below contains more information.Related packs
The following packs are required for this DFP:
- pack: ARM::CMSIS@^6.2.0 # Arm CMSIS pack 6.2.0 or higher - pack: ARM::CMSIS-Compiler@2.1.0 # Arm Compiler pack 2.1.0 or higher (for STDIN/OUT)E7 DevKit (BSP)
The E7 DevKit Board Support (BSP) part provides the following examples and layers:
Example Tool Description Blinky_M55_HE uVision IDE Blinky example running on M55 High Efficiency core Blinky_M55_HE_TCM uVision IDE Blinky example running on M55 High Efficiency core from TCM Csolution Project CMSIS-Toolbox Blinky examples configured for M55 High Performance or High Efficiency code DualCore_HE_HP CMSIS-Toolbox Dual Core example running on M55 High Efficiency and High Performance core HelloWorld_M55_HP uVision IDE Hello World example running on M55 High Performance core Zephyr_HP CMSIS-Toolbox Zephyr setup for CMSIS-Debugger on M55 High Performance core Zephyr_HE CMSIS-Toolbox Zephyr setup for CMSIS-Debugger on M55 High Efficiency core Zephyr_HE_HP CMSIS-Toolbox Zephyr setup for CMSIS-Debugger on M55 High Efficiency and High Performance core Layer Type: Board Tool Description Board_HP.clayer.ymlCMSIS-Toolbox Board layer for M55 High Performance core Board_HE.clayer.ymlCMSIS-Toolbox Board layer for M55 High Efficient core The Board Layers enable device-agnostic Reference Applications and implement these API interfaces:
Provided API Interface Description CMSIS_ETH CMSIS-Driver Ethernet connected to RJ45 connector CMSIS_VIO CMSIS-Driver VIO connected to RGB LED and Joystick CMSIS_VSTREAM_AUDIO_IN CMSIS-Driver for Audio input stream via I2S Microphones STDIN, STDOUT, STDERR Standard I/O connected to USART COM port E7 AppKit (BSP)
The E7 AppKit BSP part provides the following:
Example Tool Description Blinky_HP CMSIS-Toolbox Blinky example running on M55 High Performance core Blinky_HE CMSIS-Toolbox Blinky example running on M55 High Efficiency core DualCore_HE_HP CMSIS-Toolbox Dual Core example running on M55 High Efficiency and High Performance core Zephyr_HP CMSIS-Toolbox Zephyr setup for CMSIS-Debugger on M55 High Performance core Zephyr_HE CMSIS-Toolbox Zephyr setup for CMSIS-Debugger on M55 High Efficiency core Zephyr_HE_HP CMSIS-Toolbox Zephyr setup for CMSIS-Debugger on M55 High Efficiency and High Performance core Layer Type: Board Tool Description Board_HP.clayer.ymlCMSIS-Toolbox Board layer for M55 High Performance core Board_HE.clayer.ymlCMSIS-Toolbox Board layer for M55 High Efficient core The Board Layers enable device-agnostic Reference Applications and implement these API interfaces:
Provided API Interface Description CMSIS_VIO CMSIS-Driver VIO connected to RGB LED and Joystick CMSIS_VSTREAM_AUDIO_IN CMSIS-Driver for Audio input stream via I2S Microphones CMSIS_VSTREAM_VIDEO_IN CMSIS-Driver for Video input stream via MIPI Camera CMSIS_VSTREAM_VIDEO_OUT CMSIS-Driver for Video output stream via GLCD Display STDIN, STDOUT, STDERR Standard I/O connected to USART COM port Usage
The host PC runs the SETOOLS, IDE and debugger connects to Alif Semiconductor development boards via debug probes (J-Link, CMSIS DAP, ULINKpro). Optional, for the SETOOLS an onboard UART-to-USB interface adapter (PRG_USB) is available.
NOTE
SETOOLS are mandatory for generating and flashing processor the Application Table of Content (ATOC). The first time you load an image or change the processor setup, a ATOC image containing debug stubs must be generated and flashed onto the device prior to starting a debug session (otherwise, the debug connection will fail). After this is done once, the application can be built, flashed, and debugged without reprogramming the ATOC.Download SETOOLS from Alif Semiconductor Software & Tools page (requires registration).
The CMSIS-Toolbox examples include for VS Code a
tasks.jsonfile that generates and programs the ATOC using the SETOOLS using the following tasks:Tasks Description Alif: Install M55_HE or M55_HP debug stubs (single core configuration) Setup for HP and HE single core examples Alif: Install M55_HE and M55_HP debug stubs (dual core configuration) Setup for dualcore examples To run these tasks:
Set the variable
alif.setools.rootin the globalsettings.json. UseCtrl+,to open the settings dialog, then switch to text mode and enter (this is required only once):json { "alif.setools.root": "C:\\Alif\\SETOOLS", // SETOOLS installation path on your PC : -
Use from the VS Code menu Terminal - Run Task to execute the SETOOLS configuration task. For Windows ensure that the Terminal default is
Git BashorPowerShell.
Example output:
* Executing task: cp './.alif/M55_HE_mram_cfg.json' 'C:\Alif/build/config/M55_HE_mram_cfg.json'; cp './.alif/M55_HP_mram_cfg.json' 'C:\Alif/build/config/M55_HP_mram_cfg.json'; cp './.alif/M55_HP_mram_stub.bin' 'C:\Alif/build/images/M55_HP_mram_stub.bin'; cp './.alif/M55_HE_mram_stub.bin' 'C:\Alif/build/images/M55_HE_mram_stub.bin'; cd 'C:\Alif'; ./app-gen-toc -f 'build/config/M55_HE_mram_cfg.json'; ./app-write-mram -p -d; Generating APP Package with: Device Part# E7 (AE722F80F55D5LS) - 5.5 MRAM / 13.5 SRAM - Rev: B2 - System MRAM Base Address: 0x80580000 - APP MRAM Base Address: 0x80000000 - APP MRAM Size: 5767168 - Configuration file: build/config/M55_HE_mram_cfg.json - Output file: build/AppTocPackage.bin Generating Device Configuration for: app-device-config.json Calculating APP area... Creating Content Certificates... 2025-07-02 16:26:43,856 - Content Certificate Generation Utility started (Logging to ../build/logs/SBContent.log) : Creating APP TOC Package... Creating Signature... Binary File: ../build/images/M55_HE_mram_stub.bin 2025-07-02 16:26:44,813 - Content Certificate Generation Utility started (Logging to ../build/logs/SBContent.log) Content Certificate File: build/images/M55_HE_mram_stub.bin.crt Signature File: build/images/M55_HE_mram_stub.bin.sign Adding ATOC... APP TOC Package size: 13552 bytes Creating Signature... Binary File: ../build/AppTocPackage.bin 2025-07-02 16:26:45,057 - Content Certificate Generation Utility started (Logging to ../build/logs/SBContent.log) Content Certificate File: build/AppTocPackage.bin.crt Signature File: build/AppTocPackage.bin.sign Done! Writing MRAM with parameters: Device Part# E7 (AE722F80F55D5LS) - 5.5 MRAM / 13.5 SRAM - Rev: B2 - Available MRAM: 5767168 bytes [INFO] Burning: ../build/images/M55_HE_mram_stub.bin 0x80000000 ../build/AppTocPackage.bin 0x8057cb10 [INFO] baud rate 55000 [INFO] dynamic baud rate change Enabled COM ports detected = 2 -> COM3 -> COM6 Enter port name:COM6 [INFO] COM6 open Serial port success Maintenance Mode = Enabled Authenticate Image: False Download Image build\images\M55_HE_mram_stub.bin[####################]100%: 3040/3040 bytes Done 0.07 seconds Authenticate Image: False Download Image build\AppTocPackage.bin [####################]100%: 13552/13552 bytes Done 0.32 secondsLinks
