  1. Packs
  2. CMSIS-NN
CMSIS-NN
The CMSIS-NN software pack contains a collection of efficient neural network kernels developed to maximize performance and minimize the memory footprint of neural networks on Arm Cortex-M processors.
CMSIS-NN overview
CMSIS-NN provides optimized implementations of common neural network operators, including convolution, depthwise convolution, fully connected, pooling, activation, softmax, LSTM, and SVDF functions. Machine learning runtimes use these kernels to execute an optimized model on the Cortex-M CPU. On systems with an Arm Ethos-U NPU, a runtime can use CMSIS-NN for operators assigned to the CPU alongside operators offloaded to the NPU.
CMSIS-NN integrates with embedded machine learning frameworks including LiteRT for Microcontrollers and ExecuTorch. LiteRT can deploy models created with TensorFlow, while the ExecuTorch Arm Cortex-M backend uses CMSIS-NN kernels to accelerate quantized PyTorch models.
The integer kernels follow the int8 and int16 quantization specifications used by LiteRT. Selected operators also support int4 weights with int8 activations. Experimental float16 and float32 APIs are available for use cases where integer quantization is not suitable; these APIs are disabled by default and primarily target processors with Arm Helium Technology.
CMSIS-NN selects an implementation according to the target processor features:
  • Pure C: portable implementations for all supported Cortex-M processors.
  • DSP extension: optimized implementations using SIMD instructions.
  • Helium: optimized implementations using the Arm M-profile Vector Extension (MVE).
Availability
CMSIS-NN is available under the Apache 2.0 license and is distributed as source code and as a standalone CMSIS-Pack.
Supported Compilers
  • CMSIS-NN is tested with Arm Compiler 6 and Arm GNU Toolchain.
  • IAR compiler is not tested and may have compilation or performance issues.
  • Host compilation is not supported out of the box. The C implementation may be compiled for a host with minor stubbing.
Links
