- Packs
- CMSIS-Driver_PIC32CZ-MC70
1.0.0-
Pack Type
Software Pack
Microchip PIC32CZ-MC70 Series CMSIS Driver Support
Add to CMSIS Solution
packs:- pack: Microchip::CMSIS-Driver_PIC32CZ-MC70@1.0.0
Add with cpackget
> cpackget add Microchip::CMSIS-Driver_PIC32CZ-MC70@1.0.0
Download
Microchip.CMSIS-Driver_PIC32CZ-MC70.1.0.0.packOverview
This pack provides comprehensive support for the CMSIS Driver interface and PIC32CZ-MC70 device specific peripherals. This pack enables developers to leverage the standardized CMSIS Driver API for seamless integration and portability across ARM Cortex-M based platforms, while also offering optimized access to Microchip's hardware features. It is designed to accelerate development, improve code reusability, and simplify peripheral management for PIC32CZ-MC70 microcontrollers.
Key features include: - CMSIS Driver support for PIC32CZ-MC70 devices. - Integration with Microchip-specific peripheral APIs(Plibs). - Blank solution to help you get started quickly.
Supported Devices
Devices supported in this pack are:
PIC32CZ-MC70 Family: - PIC32CZ1038MC70064 - PIC32CZ1038MC70100 - PIC32CZ2051MC70064 - PIC32CZ2051MC70100
Related Packs
To use this GSP pack effectively, ensure the following related packs are included in your project:
Pack Name Description ARM::CMSISARM CMSIS core and driver definitions ARM::CMSIS-CompilerCMSIS compiler abstraction layer providing portable compiler intrinsics, attributes, and startup support across Arm toolchains Microchip::PIC32CZ-MC70_DFPDevice Family Pack for PIC32CZ-MC70 devices
Included Solutions
The pack contains the following solution:
- Blank MCHP Driver Solution
A template solution for starting new projects with Microchip CMSIS Driver support.
Supported CMSIS software components
This pack provides support for the following software components:
Component Description MCHP-PLIB:ACC Analog Comparator Controller MCHP-PLIB:AFEC Analog Front-End Controller MCHP-PLIB:DACC Digital-to-Analog Converter Controller MCHP-PLIB:EFC Embedded Flash Controller MCHP-PLIB:HSMCI High Speed MultiMedia Card Interface MCHP-PLIB:ICM Integrity Check Monitor MCHP-PLIB:MATRIX AHB Bus Matrix MCHP-PLIB:PIO Parallel Input/Output Controller MCHP-PLIB:PMC Power Management Controller MCHP-PLIB:PWM Pulse Width Modulation Controller MCHP-PLIB:QSPI Quad Serial Peripheral Interface MCHP-PLIB:RSTC Reset Controller MCHP-PLIB:RSWDT Reinforced Safety Watchdog Timer MCHP-PLIB:RTC Real-time Clock MCHP-PLIB:RTT Real-time Timer MCHP-PLIB:SPI Serial Peripheral Interface MCHP-PLIB:SSC Synchronous Serial Controller MCHP-PLIB:SUPC Supply Controller / General Purpose Backup Registers(GPBR) MCHP-PLIB:TC Timer Counter MCHP-PLIB:TRNG True Random Number Generator MCHP-PLIB:TWIHS Two-wire Interface High Speed MCHP-PLIB:UART Universal Asynchronous Receiver Transmitter MCHP-PLIB:USART Universal Synchronous Asynchronous Receiver Transmitter MCHP-PLIB:WDT Watchdog Timer MCHP-PLIB:XDMAC Extensible DMA Controller CMSIS Driver:GPIO General Purpose Input/Output (GPIO) Driver CMSIS Driver:USART Universal Synchronous/Asynchronous Receiver/Transmitter Driver CMSIS Driver:SPI Serial Peripheral Interface (SPI0) Driver CMSIS Driver:Flash Flash Memory Driver Support
