- Packs
- CMSIS-Driver_PIC32CM-JH
1.0.0-
Pack Type
Software Pack
Microchip PIC32CM-JH Series CMSIS Driver Support
Add to CMSIS Solution
packs:- pack: Microchip::CMSIS-Driver_PIC32CM-JH@1.0.0
Add with cpackget
> cpackget add Microchip::CMSIS-Driver_PIC32CM-JH@1.0.0
Download
Microchip.CMSIS-Driver_PIC32CM-JH.1.0.0.packOverview
This pack provides comprehensive support for the CMSIS Driver interface and PIC32CM-JH device specific peripherals. This pack enables developers to leverage the standardized CMSIS Driver API for seamless integration and portability across ARM Cortex-M based platforms, while also offering optimized access to Microchip's hardware features. It is designed to accelerate development, improve code reusability, and simplify peripheral management for PIC32CM-JH microcontrollers.
Key features include: - CMSIS Driver support for PIC32CM-JH devices. - Integration with Microchip-specific peripheral drivers. - Blank solution to help you get started quickly.
Supported Devices
Devices supported in this pack are:
PIC32CM-JH00 Family: - PIC32CM2532JH00032 - PIC32CM2532JH00048 - PIC32CM2532JH00064 - PIC32CM2532JH00100 - PIC32CM5164JH00032 - PIC32CM5164JH00048 - PIC32CM5164JH00064 - PIC32CM5164JH00100
PIC32CM-JH01 Family: - PIC32CM1216JH01032 - PIC32CM1216JH01048 - PIC32CM2532JH01032 - PIC32CM2532JH01048 - PIC32CM2532JH01064 - PIC32CM2532JH01100 - PIC32CM5164JH01032 - PIC32CM5164JH01048 - PIC32CM5164JH01064 - PIC32CM5164JH01100
PIC32CM64_32-JH00 Family: - PIC32CM3204JH00032 - PIC32CM3204JH00048 - PIC32CM3204JH00064 - PIC32CM6408JH00032 - PIC32CM6408JH00048 - PIC32CM6408JH00064
Related Packs
To use this GSP pack effectively, ensure the following related packs are included in your project:
Pack Name Description ARM::CMSISARM CMSIS core and driver definitions ARM::CMSIS-CompilerCMSIS compiler abstraction layer providing portable compiler intrinsics, attributes, and startup support across Arm toolchains Microchip::PIC32CM-JH_DFPDevice Family Pack for PIC32CM-JH devices
Included Solutions
The pack contains the following solution:
- Blank_MCHP_Driver_Solution
A template solution for starting new projects with Microchip CMSIS Driver support.
Limitations
- CAN PLIB is not supported in this pack.
Support
