- Packs
- CMSIS-Compiler
CMSIS-Compiler
2.2.0-
Pack Type
Software Pack
CMSIS Compiler extensions for Arm Compiler, GCC, Clang, and IAR Compiler
Add to CMSIS Solution
packs:- pack: ARM::CMSIS-Compiler@2.2.0
Add with cpackget
> cpackget add ARM::CMSIS-Compiler@2.2.0
Download
ARM.CMSIS-Compiler.2.2.0.packRepository
CMSIS-CompilerOverview
CMSIS-Compiler provides software components that simplify retargeting of standard C run-time library functions.
Application code frequently uses standard C library functions, such as
fopen,fwrite,printf(),scanf()and others to perform input/output operations. These functions may as well be used in a multithreaded environment.The structure of these functions in the standard C run-time library together with the retarget interfaces is:
Standard C library functions are platform independent and can be easily ported, while the low-level interfaces needs to be tailored to the chosen platform. Generally low-level I/O functions serve to interact with the file system and a serial interface, i.e. terminal. Multithreading support is available for applications that run on top of an RTOS kernel.
CMSIS-Compiler enables platform specific retargeting by providing software components that break down into the following interfaces:
- File interface that enables reading and writing files
- STDIN interface that enables standard input stream redirection
- STDOUT interface that enables standard output stream redirection
- STDERR interface that enables standard error stream redirection
- OS interface that enables multithread safety using an arbitrary RTOS
Using CMSIS-Compiler developers can retarget standard I/O streams and file operations to specific platform and enable thread safe operations using RTOS interface.
Links
