  1. Packs
  2. T2G-C-2D_DFP
The Infineon KIT_T2G-C-2D Device Family Pack (DFP) is a CMSIS-Pack that:
  • Enables compatible tools with device support.
  • Supports Arm Compiler 6 (AC6), GCC, and IAR.
  • Contains System View Description (SVD) descriptions of the peripherals.
  • Flash algorithms for the on-chip Flash memory.
  • Debug configuration information.
  • Infineon Peripheral driver library (PDL).
Infineon's MTB CAT1C Peripheral driver library (PDL) Support
This DFP is tested with the Infineon's MTB CAT1C Peripheral driver library (PDL)
Infineon's MTB CAT1C PDL provides low level device drivers. It integrates device header files, and peripheral drivers into a single package. The drivers abstract the hardware functions into a set of easy-to-use APIs. These are fully documented in the PDL API Reference
Infineon Device Configurator Support
The device is configured using Device Configurator. Refer to Infineon Device Configurator user guide for Device Configurator usage information.
Add this component to your csolution project to connect to Device Configurator.
    - component: CMSIS:CORE
    - component: Device Configurator                # Component that launches Device Configurator
Usage in VS Code
The VS Code Arm CMSIS Solution extension lets you run Device Configurator from the CMSIS Solution View.
  • Use Run Generator that is available for the component Device:Device Configurator in the CMSIS Solution View. This starts Device Configurator and once the configuration is completed save once. The generated code is imported to GeneratedSource folder.
Usage in uVision
The uVision lets you run Device Configurator from the Manage Run-Time Environment Window.
  • Select a device and enable in the Manage Run-Time Environment Window the components:
  • CMSIS:CORE
  • Device:GeneratedSource
  • Use Launch GeneratedSource that is available for the component Device:GeneratedSource in the Manage Run-Time Environment Window. This starts GeneratedSource and once the configuration is completed save and close. The generated code is imported to GeneratedSource folder.
Supported Devices
This DFP supports KIT_T2G-C-2D_6M_LITE Kit
List of devices supported
T2G-C-2D_6M
1 CYT4DNJBAS
2 CYT4DNJBBS
3 CYT4DNJBCS
4 CYT4DNJBDS
5 CYT4DNJBES
6 CYT4DNJBFS
7 CYT4DNJBGS
8 CYT4DNJBHS
9 CYT4DNJBJS
10 CYT4DNJKS
11 CYT4DNJLS
12 CYT4DNJMS
13 CYT4DNJNS
14 CYT4DNJPS
15 CYT4DNJQS
16 CYT4DNJRS
17 CYT4DNJSS
18 CYT4DNJVS
19 CYT4DNJYS
20 CYT4DNJZS
