- Packs
- T2G-C-2D_DFP
T2G-C-2D_DFP
1.0.0-
Pack Type
Device Support
Infineon KIT_T2G_C_2D_6M_LITE Device Family Pack
Add to CMSIS Solution
packs:- pack: Infineon::T2G-C-2D_DFP@1.0.0
Add with cpackget
> cpackget add Infineon::T2G-C-2D_DFP@1.0.0
Download
Infineon.T2G-C-2D_DFP.1.0.0.packIntroduction
The Infineon KIT_T2G-C-2D Device Family Pack (DFP) is a CMSIS-Pack that:
- Infineon Peripheral driver library (PDL).
Infineon's MTB CAT1C Peripheral driver library (PDL) Support
This DFP is tested with the Infineon's MTB CAT1C Peripheral driver library (PDL)
Infineon's MTB CAT1C PDL provides low level device drivers. It integrates device header files, and peripheral drivers into a single package. The drivers abstract the hardware functions into a set of easy-to-use APIs. These are fully documented in the PDL API Reference
Infineon Device Configurator Support
The device is configured using Device Configurator. Refer to Infineon Device Configurator user guide for Device Configurator usage information.
Add this component to your csolution project to connect to Device Configurator.
- component: CMSIS:CORE - component: Device Configurator # Component that launches Device ConfiguratorUsage in VS Code
The VS Code Arm CMSIS Solution extension lets you run Device Configurator from the CMSIS Solution View.
- Use
Run Generatorthat is available for the componentDevice:Device Configuratorin the CMSIS Solution View. This starts Device Configurator and once the configuration is completed save once. The generated code is imported to GeneratedSource folder.
Usage in uVision
The uVision lets you run Device Configurator from the Manage Run-Time Environment Window.
Select a device and enable in the Manage Run-Time Environment Window the components:
CMSIS:CORE -
Device:GeneratedSource -
Use
Launch GeneratedSourcethat is available for the componentDevice:GeneratedSourcein the Manage Run-Time Environment Window. This starts GeneratedSource and once the configuration is completed save and close. The generated code is imported to GeneratedSource folder.
Supported Devices
This DFP supports KIT_T2G-C-2D_6M_LITE Kit
List of devices supported
T2G-C-2D_6M 1 CYT4DNJBAS 2 CYT4DNJBBS 3 CYT4DNJBCS 4 CYT4DNJBDS 5 CYT4DNJBES 6 CYT4DNJBFS 7 CYT4DNJBGS 8 CYT4DNJBHS 9 CYT4DNJBJS 10 CYT4DNJKS 11 CYT4DNJLS 12 CYT4DNJMS 13 CYT4DNJNS 14 CYT4DNJPS 15 CYT4DNJQS 16 CYT4DNJRS 17 CYT4DNJSS 18 CYT4DNJVS 19 CYT4DNJYS 20 CYT4DNJZS
