- Packs
- STM32L4xx_DFP
STM32L4xx_DFP
3.1.0-
Pack Type
Device Support
STMicroelectronics STM32L4 Series Device Support
Add to CMSIS Solution
packs:- pack: Keil::STM32L4xx_DFP@3.1.0
Add with cpackget
> cpackget add Keil::STM32L4xx_DFP@3.1.0
Download
Keil.STM32L4xx_DFP.3.1.0.packRepository
STM32L4xx_DFPIntroduction
The STMicroelectronics STM32L4 Series Device Family Pack (DFP) is a CMSIS-Pack that:
CMSIS-Driver Support
- component: CMSIS-Driver:GPIO # GPIO Driver for STM32 devices - component: CMSIS-Driver:I2C # I2C Driver for STM32 devices - component: CMSIS-Driver:MCI # MCI Driver for STM32 devices - component: CMSIS-Driver:SPI # SPI Driver for STM32 devices - component: CMSIS-Driver:USART # USART Driver for STM32 devices - component: CMSIS-Driver:USB Device # USB Device Driver for STM32 devices - component: CMSIS-Driver:USB Host # USB Host Driver for STM32 devicesCubeMX Support
- component: CMSIS:CORE - component: Device:CubeMX # Component that connects to CubeMXImportant Note:
The DFP does not contain Startup and System Configuration files and does not provide the
CMSIS_device_headerprovided by the CMSIS-Core that defines the registers and interrupt mapping. This files are provided by the CubeMX firmware pack. It is therefore mandatory to use CubeMX when using this DFP as it will pull-in these files and make it accessible.Usage in VS Code
In the dialog Create New Solution choose a device or board and select a CubeMX template (which contains the
Device:CubeMXcomponent). -
Use
Run Generatorthat is available for the componentDevice:CubeMXin the CMSIS Solution View. This starts CubeMX and once the configuration is complete, click in CubeMX the buttonGENERATE CODE. The generated code is imported with fileCubeMX.cgen.ymlas shown below.
Note:
Usage in uVision
Select a device and enable in the Manage Run-Time Environment Window the components:
CMSIS:CORE -
Device:CubeMX -
Use
Launch CubeMXthat is available for the componentDevice:CubeMXin the Manage Run-Time Environment Window. This starts CubeMX and once the configuration is complete, click in CubeMX the buttonGENERATE CODE. The generated code is imported with fileCubeMX.cgen.yml.
