- Packs
- STM32H7RSxx_DFP
STM32H7RSxx_DFP
1.1.0-
            Pack TypeDevice Support
STMicroelectronics STM32H7RSxx Series Device Support
    Add to CMSIS Solutionpacks:- pack: Keil::STM32H7RSxx_DFP@1.1.0 Add with cpackget> cpackget add Keil::STM32H7RSxx_DFP@1.1.0 DownloadKeil.STM32H7RSxx_DFP.1.1.0.packRepositorySTM32H7RSxx_DFPIntroductionThe STMicroelectronics STM32H7RS Series Device Family Pack (DFP) is a CMSIS-Pack that: - Enables compatible tools with device support.
 CMSIS-Driver SupportThis DFP is tested with the CMSIS-Driver_STM32 pack that implements CMSIS-Driver interfaces using a shim layer to the STM32Cube HAL. The following drivers are supported. - component: CMSIS-Driver:Ethernet MAC # Ethernet MAC Driver for STM32 devices - component: CMSIS-Driver:GPIO # GPIO Driver for STM32 devices - component: CMSIS-Driver:I2C # I2C Driver for STM32 devices - component: CMSIS-Driver:MCI # MCI Driver for STM32 devices - component: CMSIS-Driver:SPI # SPI Driver for STM32 devices - component: CMSIS-Driver:USART # USART Driver for STM32 devices - component: CMSIS-Driver:USB Device # USB Device Driver for STM32 devices - component: CMSIS-Driver:USB Host # USB Host Driver for STM32 devicesCubeMX SupportThe device is configured using STM32CubeMX (CubeMX). Refer to CMSIS-Toolbox - Configure STM32 Devices with CubeMX for usage information with csolution projects. Add this component to your csolution project to connect to CubeMX. - component: CMSIS:CORE - component: Device:CubeMX # Component that connects to CubeMXNotes: - Required STM32CubeMX 6.14.0 or higher.
- Limitation of STM32CubeMX 6.14.0: Peripheral SDMMC must be disabled, otherwise STM32CubeMX hangs!
 Important Note: The DFP does not contain Startup and System Configuration files and does not provide the CMSIS_device_headerprovided by the CMSIS-Core that defines the registers and interrupt mapping. This files are provided by the CubeMX firmware pack. It is therefore mandatory to use CubeMX when using this DFP as it will pull-in these files and make it accessible.Usage in VS CodeThe VS Code Arm CMSIS Solution extension lets you run CubeMX from the CMSIS Solution View. -
In the dialog Create New Solution choose a device or board and select a CubeMX template (which contains the Device:CubeMXcomponent).
Use Run Generatorthat is available for the componentDevice:CubeMXin the CMSIS Solution View. This starts CubeMX and once the configuration is complete, click in CubeMX the buttonGENERATE CODE. The generated code is imported with fileCubeMX.cgen.ymlas shown below.
  Note: Refer to CMSIS-Toolbox - Configure STM32 Devices with CubeMX for usage information. It contains useful hints, for example for the configuration of an RTOS. Usage in uVisionUsage of µVision for STM32H7RS devices is limited, as the usual workflow with CubeMX is not fully supported. The code generated by CubeMX is not imported into µVision. However, µVision can still be used for debugging by opening an existing Csolution project.
