- Packs
- STM32G474E-EVAL1_BSP
1.1.0-
Pack Type
Board Support
STMicroelectronics STM32G4 Series STM32G474E-EVAL1 Board Support Pack
Add to CMSIS Solution
packs:
- pack: Keil::STM32G474E-EVAL1_BSP@1.1.0
Add with cpackget
> cpackget add Keil::STM32G474E-EVAL1_BSP@1.1.0
Download
Keil.STM32G474E-EVAL1_BSP.1.1.0.packRepository
STM32G474E-EVAL1_BSPSTM32G474E-EVAL1_BSP
The STMicroelectronics STM32G474E-EVAL1 Board Support Pack (BSP):
- Contains examples and board layers in csolution format for usage with the CMSIS-Toolbox and the VS Code CMSIS Solution extension.
- Requires the Device Family Pack (DFP) for the STM32G4 series.
- Is configured with STM32CubeMX for the Arm Compiler 6 (MDK). Using GCC Compiler explains how to configured it for a different compiler.
Content in csolution format
Examples/Blinky shows the basic usage of this board.
Board Layer for device-agnostic Reference Applications that implements these API interfaces:
Provided API Interface Description CMSIS_USART CMSIS-Driver USART connected to Motor-control connector (pins 5, 9) (CN4) CMSIS_USB_Device CMSIS-Driver USB Device connected to USB_FS connector (CN22) CMSIS_VIO CMSIS-Driver VIO connected to LEDs (LD3, LD1) and TAMPER button (B2) STDIN, STDOUT, STDERR Standard I/O connected to Virtual COM port on ST-LINK connector (CN21) Using GCC Compiler
- In the
<solution_name>.csolution.yml
project file selectcompiler: GCC
. - Launch the STM32CubeMX generator with this CMSIS-Toolbox command:
csolution <solution_name>.csolution.yml run -g CubeMX -c <context>
- In STM32CubeMX:
- Open from the menu
Project Manager - Project - Toolchain/IDE
: - Select
STM32CubeIDE
and disableGenerate Under Root
Click
GENERATE CODE
to recreate the CubeMX generated files for the GCC compiler. -
In the
Board.clayer.yml
file, updatelinker:
node configuration to reference appropriate GCC linker script. The GCC linker script is typically generated in theSTM32CubeMX/STM32CubeIDE
folder. Customize the GCC linker script file to your project's requirements. - Rebuild the project using the CMSIS-Toolbox command
cbuild <solution_name>.csolution.yml
