- Packs
- SAMR21_DFP
SAMR21_DFP
2.2.179-
Pack Type
Device Support
Microchip SAMR21 Series Device Support
Add to CMSIS Solution
packs:- pack: Microchip::SAMR21_DFP@2.2.179
Add with cpackget
> cpackget add Microchip::SAMR21_DFP@2.2.179
Download
Microchip.SAMR21_DFP.2.2.179.packOverview
The Microchip SAMR21 Series Device Family Pack (DFP) is a CMSIS-Pack that:
- Contains support files for the MPLAB XC32 Compiler.
- Contains support files for the GCC compiler.
- Contains support files for the Arm Compiler for Embedded.
- Contains support files for the IAR Embedded Development Tools.
- Flash algorithms for the on-chip flash memory.
Related packs
- pack: ARM::CMSISDevices
ATSAMR21E16A
An IEEE 802.15.4 compliant single chip combines an ARM® Cortex®-M0+ based 32-bit microcontroller and best-in-class 2.4GHz RF transceiver. It offers an excellent RF performance, with a link budget of 103dBm while consuming 50% less active current than existing offerings. The device features IEEE 802.15.4 MAC hardware accelerators and automatic transmission modes, wake-on-radio, offers twelve-channel direct memory access (DMA) controller, up to four configurable SERCOM modules for I2C, SPI and USART and a 128-bit AES crypto engine. The device features further blocks like a Peripheral Touch Controller (PTC), Full-Speed USB Device and embedded Host and hardware components to support RF distance measurements. To complement that set the SAM R21 also supports external power amplifiers and antenna diversity.Microchip's complimentary and confidential Wireless Check online design review service is available for customers who have selected our products for their application design-in. The online design review service is subject to Microchip's Program Terms and Conditions and requires a myMicrochip account.
Documentation:
Application Notes:
- AVR10002: ATmega256RFR2 Evaluation Kit - User Guide
- AVR10004: RCB256RFR2 - Hardware User Manual
- AT06482: Real Color ZLL LED Light Bulb with ATmega256RFR2 - Software User`s Guide
- AT04464: Wireless SoC Reference Design with RFMDs RF6505
- AT06700: LED Commercial Lighting Kit and Gateway Software User`s Guide
- AT06412: Real Color ZLL LED Light Bulb with ATmega256RFR2 - Hardware User Guide
- AT03201: 100W Commercial LED Light with Wireless Connection - Hardware User Guide
- AT02865: RF Layout with Microstrip
- AT12459: FCC Test for IEEE 802.15.4 Transmitters
- AVR2130: Lightweight Mesh Developer Guide
- AVR2131: Lightweight Mesh Getting Started Guide
- AT02430: Supporting TWIGEN Interface in Serial Bootloader (AVR2054)
- AT05436: BitCloud ZigBee Home Automation (ZHA) - Hands-on
- AT01030: Low-cost Ethernet to Wireless Gateway with ATmega256RFR2
- AT02607: Wireless Product Development Using Studio and ASF
- AT09567: ISM Band PCB Antenna Reference Design
- AT02594: Smart Reduced Power Consumption Techniques
- AT16802: Antenna Tune Up
- AT07926: Connecting Wireless Networks to the Internet using Xively Technology
- AT03188: Performance Test EVK with External FEM
- AVR477: RF4Control - Touch Remote Control
- AVR417: ZLL Gateway Getting Started Guide
- AVR2068: RF4CE-HID QTouch Analyzer Target for AVR477
- AVR2054: SerialBootloader User Guide
- AT02597: ZigBee PRO Packet Analysis with Sniffer
- AT14615: ZigBee Broadcast Message Handling and Implementation in BitCloud SDK
Additional Documents:
- Wireless Brochure
- Atmel Studio - Software Development Environment
- Atmel 802.15.4 MCUs Solutions
- RCB256RFR2-XPRO User Guide
- REB233-XPRO User Guide
- ZigBit USB Stick User Guide
- Atmel Xplained Pro - Atmel Xplained Pro kits provide a complete and easy to use low-cost development platform for evaluating and prototyping your Atmel Flash-based microcontrollers (MCUs) designs.
- Atmel IEEE 802.15.4 Solutions
- ZigBit Extension User Guide
- Atmel AT13519: ATSAMR21 LED Driver with ZigBee Light Link - Firmware User Guide
- AN_42115 - AT03255: SAM D/R/L/C Serial Peripheral Interface (SERCOM SPI) Driver
- AN_42118 - AT03256: SAM D/R/L/C Serial USART (SERCOM USART) Driver
- AN_42119 - AT03259: SAM D/R System Clock Management (SYSTEM CLOCK) Driver
- AN_42120 - AT03260: SAM D/R System (SYSTEM) Driver
- AN_42116 - AT03254: SAM D/R/L/C I2C Slave Mode (SERCOM I2C) Driver
- AN_42122 - AT03261: SAM D/R/L/C System Interrupt (SYSTEM INTERRUPT) Driver
- AN_42121 - AT03262: SAM D/R/L/C System Pin Multiplexer (SYSTEM PINMUX) Driver
- AN_42123 - AT03263: SAM D/R/L/C Timer Counter (TC) Driver
- AN_42124 - AT03264: SAM D/R/L/C Watchdog (WDT) Driver
- AN_42126 - AT03266: SAM D/R/L/C RTC Calendar (RTC CAL) Driver
- AN_42125 - AT03265: SAM D10/D11/D20/D21/R/L/C EEPROM Emulator (EEPROM) Service
- AN_42257 - AT07683: SAM D09/D10/D11/D21/DA1/R/L/C Direct Memory Access Controller (DMAC) Driver
- AN_42256 - AT07058: SAM D10/D11/D21/DA1/R/L/C Timer Counter for Control Applications (TCC) Driver
- AN_42149 - AT03789: SAM D10/D11/D20/D21/DA1/R Brown Out Detector (BOD) Driver
- AN_42107 - AT03229: SAM D/R/L/C Peripheral Access Controller (PAC) Driver
- AN_42106 - AT03242: SAM D20/D21/D10/D11/DA1/L/C Analog Comparator (AC) Driver
- AN_42109 - AT03243: SAM D/R Analog to Digital Converter (ADC) Driver
- AN_42108 - AT03245: SAM D/R/L/C Event System (EVENTS) Driver
- AN_42112 - AT03246: SAM D/R/L/C External Interrupt (EXTINT) Driver
- AN_42114 - AT03247: SAM D/R/L/C Non-Volatile Memory (NVM) Driver
- AN_42113 - AT03248: SAM D/R/L/C Port (PORT) Driver
- AN_42111 - AT03249: SAM D/R/L/C RTC Count (RTC COUNT) Driver
- AN_42117 - AT03250: SAM D/R/L/C I2C Master Mode (SERCOM I2C) Driver
- ASF4 API Reference Manual
- Wireless Hardware Design Checklist
- MiWi™ Software Design Guide
- MiWi Quick Start Guide
- MiWi Migration Guide User Guide
- Computers that You Wear Help Your Work and Play
- Designing Feature-Rich User Interfaces for Home and Industrial Controllers
ATSAMR21E17A
Documentation:
Application Notes:
- Wireless Brochure
ATSAMR21E18A
An IEEE 802.15.4 compliant single chip combines an ARM® Cortex®-M0+ based 32-bit microcontroller and best-in-class 2.4GHz RF transceiver. It offers an excellent RF performance, with a link budget of 103dBm while consuming 50% less active current than existing offerings. The device features IEEE 802.15.4 MAC hardware accelerators and automatic transmission modes, wake-on-radio, offers twelve-channel direct memory access (DMA) controller, up to four configurable SERCOM modules for I2C, SPI and USART and a 128-bit AES crypto engine. The device features further blocks like a Peripheral Touch Controller (PTC), Full-Speed USB Device and embedded Host and hardware components to support RF distance measurements. To complement that set the SAM R21 also supports external power amplifiers and antenna diversity.The ATSAMR21E18A is available in a fully-certified module, ATSAMR21B18, optimized for zigbee lighting designs. Visit the module product page for more information. Microchip's complimentary and confidential Wireless Check online design review service is available for customers who have selected our products for their application design-in. The online design review service is subject to Microchip's Program Terms and Conditions and requires a myMicrochip account.
Documentation:
Application Notes:
- AT14164: User Calibration of Internal Temperature Sensor - SAM R21
- AT14341: WSNMonitor Communication Protocol
- AN4815-Zigbee® Packet Analysis
- Wireless Brochure
ATSAMR21E19A
Documentation:
Application Notes:
- Wireless Brochure
ATSAMR21G16A
Documentation:
Application Notes:
- AT08973: SAMR21 Basic Connections and Wireless Design
- Wireless Brochure
ATSAMR21G17A
Documentation:
Application Notes:
- Wireless Brochure
ATSAMR21G18A
An IEEE 802.15.4 compliant single chip combines an ARM® Cortex®-M0+ based 32-bit microcontroller and best-in-class 2.4GHz RF transceiver. It offers an excellent RF performance, with a link budget of 103dBm while consuming 50% less active current than existing offerings. The device features IEEE 802.15.4 MAC hardware accelerators and automatic transmission modes, wake-on-radio, offers twelve-channel direct memory access (DMA) controller, up to four configurable SERCOM modules for I2C, SPI and USART and a 128-bit AES crypto engine. The device features further blocks like a Peripheral Touch Controller (PTC), Full-Speed USB Device and embedded Host and hardware components to support RF distance measurements. To complement that set the SAM R21 also supports external power amplifiers and antenna diversity.The ATSAMR21G18A is available in a regulatory-certified module, ATSAMR21G18. The ATSAMR21G18 is a full-featured module with multiple I/O and dual u.FL connectors for external antennas. Visit the module product page for more information.Microchip's complimentary and confidential Wireless Check online design review service is available for customers who have selected our products for their application design-in.The online design review service is subject to Microchip's Program Terms and Conditions and requires a myMicrochip account.
Documentation:
Application Notes:
- AT11309: Advanced RF Layout with Altium
- Wireless Brochure
MISRA-C:2023 Compliance Deviations List
Deviation ID: MFWCG-40
- Rule 5.5: Identifiers shall be distinct from macro names.
- Use case: Identifiers corresponding to register names.
Example:
```C typedef union { struct { uint32_t GPIO:29; uint32_t :3; } vec; uint32_t reg; } ECIA_SRC8_Type;
#define GPIO (0x40081000) ```
- Reason: Access to hardware.
The macros expand into the same identifiers, which allow users to detect for the presence of specific registers during preprocessing.
- Scope: Device headers for the DEC15xx and MEC15xx family
<device-name>.h).
Deviation ID: MFWCG-42
- Rule 20.9: All identifiers used in the controlling expression of
#ifor#elifpreprocessing directives shall be#define'd before evaluation. - Use case: Use of compiler builtin macros.
Example:
C #ifdef (__ARM_FP == 14) || (__ARM_FP == 4) fpu_enable(); #endif- Reason: Access to hardware.
Headers may rely on builtin macros from the compiler and are written under the assumption that if the macro is not defined, its value is zero.
- Scope: All device headers (
<device-name>.h).
Deviation ID: MFWCG-43
- Rule 21.1:
#defineand#undefshall not be used on a reserved identifier or reserved macro name. - Use case: Reserved names, beginning with
_followed by a capital letter or__followed by a lower-case are within the compiler's namespace.
Example:
C #define __IO volatile- Reason: Access to hardware; Code Quality (Usability: Accessibility).
Within these headers originate many reserved names that are within the compiler's namespace.
<device-name>.h).
Deviation ID: MFWCG-44
- Rule 21.2: A reserved identifier or reserved macro name shall not be declared.
Example:
C extern const VECTOR_TABLE_Type __VECTOR_TABLE;- Reason: Access to hardware; Code Quality (Usability: Accessibility).
<device-name>.h).
Support
