  1. Packs
  2. PSoC-HVMS_DFP
The Infineon KIT_PSoC4-HVMS Device Family Pack (DFP) is a CMSIS-Pack that:
  • Enables compatible tools with device support.
  • Supports Arm Compiler 6 (AC6), GCC, and IAR.
  • Contains System View Description (SVD) descriptions of the peripherals.
  • Flash algorithms for the on-chip Flash memory.
  • Debug configuration information.
  • Infineon Peripheral driver library (PDL).
Infineon's MTB CAT2 Peripheral driver library (PDL) Support
This DFP is tested with the Infineon's MTB CAT2 Peripheral driver library (PDL)
Infineon's MTB CAT2 PDL provides low level device drivers. It integrates device header files, and peripheral drivers into a single package. The drivers abstract the hardware functions into a set of easy-to-use APIs. These are fully documented in the PDL API Reference
Infineon Device Configurator Support
The device is configured using Device Configurator. Refer to Infineon Device Configurator user guide for Device Configurator usage information.
Add this component to your csolution project to connect to Device Configurator.
    - component: CMSIS:CORE
    - component: Device Configurator                # Component that launches Device Configurator
Usage in VS Code
The VS Code Arm CMSIS Solution extension lets you run Device Configurator from the CMSIS Solution View.
  • Use Run Generator that is available for the component Device:Device Configurator in the CMSIS Solution View. This starts Device Configurator and once the configuration is completed save once. The generated code is imported to GeneratedSource folder.
Usage in uVision
The uVision lets you run Device Configurator from the Manage Run-Time Environment Window.
  • Select a device and enable in the Manage Run-Time Environment Window the components:
  • CMSIS:CORE
  • Device:GeneratedSource
  • Use Launch GeneratedSource that is available for the component Device:GeneratedSource in the Manage Run-Time Environment Window. This starts GeneratedSource and once the configuration is completed save and close. The generated code is imported to GeneratedSource folder.
Supported Devices
This DFP supports PSoC HVMS 128K and PSoC HVMS 64K KITs
List of devices supported for PSoC HVMS 128K and PSoC HVMS 64K
PSoC™ HVMS-128K
1 CY8C4127LDE-HVS004 25 CY8C4127LWE-HVS105
2 CY8C4127LDE-HVS014 26 CY8C4127LWE-HVS115
3 CY8C4147LDE-HVS004 27 CY8C4147LWE-HVS105
4 CY8C4147LDE-HVS014 28 CY8C4147LWE-HVS115
5 CY8C4147LDE-HVS024 29 CY8C4147LWE-HVS125
6 CY8C4147LDE-HVS034 30 CY8C4147LWE-HVS135
7 CY8C4147LDE-HVS024X 31 CY8C4147LWE-HVS125X
8 CY8C4147LDE-HVS034X 32 CY8C4147LWE-HVS135X
9 CY8C4127LDE-HVS104 33 CY8C4127LQE-HVS006
10 CY8C4127LDE-HVS114 34 CY8C4127LQE-HVS016
11 CY8C4147LDE-HVS104 35 CY8C4147LQE-HVS006
12 CY8C4147LDE-HVS114 36 CY8C4147LQE-HVS016
13 CY8C4147LDE-HVS124 37 CY8C4147LQE-HVS026
14 CY8C4147LDE-HVS134 38 CY8C4147LQE-HVS036
15 CY8C4147LDE-HVS124X 39 CY8C4147LQE-HVS026X
16 CY8C4147LDE-HVS134X 40 CY8C4147LQE-HVS036X
17 CY8C4127LWE-HVS005 41 CY8C4127LQE-HVS106
18 CY8C4127LWE-HVS015 42 CY8C4127LQE-HVS116
19 CY8C4147LWE-HVS005 43 CY8C4147LQE-HVS106
20 CY8C4147LWE-HVS015 44 CY8C4147LQE-HVS116
21 CY8C4147LWE-HVS025 45 CY8C4147LQE-HVS126
22 CY8C4147LWE-HVS035 46 CY8C4147LQE-HVS136
23 CY8C4147LWE-HVS025X 47 CY8C4147LQE-HVS126X
24 CY8C4147LWE-HVS035X 48 CY8C4147LQE-HVS136X
PSoC™ HVMS-64K
1 CY8C4125LCE-HVS003 25 CY8C4125LDE-HVS104
2 CY8C4125LCE-HVS013 26 CY8C4125LDE-HVS114
3 CY8C4126LCE-HVS003 27 CY8C4126LDE-HVS104
4 CY8C4126LCE-HVS013 28 CY8C4126LDE-HVS114
5 CY8C4146LCE-HVS003 29 CY8C4146LDE-HVS104
6 CY8C4146LCE-HVS013 30 CY8C4146LDE-HVS114
7 CY8C4146LCE-HVS003X 31 CY8C4146LDE-HVS104X
8 CY8C4146LCE-HVS013X 32 CY8C4146LDE-HVS114X
9 CY8C4125LCE-HVS103 33 CY8C4125LWE-HVS005
10 CY8C4125LCE-HVS113 34 CY8C4125LWE-HVS015
11 CY8C4126LCE-HVS103 35 CY8C4126LWE-HVS005
12 CY8C4126LCE-HVS113 36 CY8C4126LWE-HVS015
13 CY8C4146LCE-HVS103 37 CY8C4146LWE-HVS005
14 CY8C4146LCE-HVS113 38 CY8C4146LWE-HVS015
15 CY8C4146LCE-HVS103X 39 CY8C4146LWE-HVS005X
16 CY8C4146LCE-HVS113X 40 CY8C4146LWE-HVS015X
17 CY8C4125LDE-HVS004 41 CY8C4125LWE-HVS105
18 CY8C4125LDE-HVS014 42 CY8C4125LWE-HVS115
19 CY8C4126LDE-HVS004 43 CY8C4126LWE-HVS105
20 CY8C4126LDE-HVS014 44 CY8C4126LWE-HVS115
21 CY8C4146LDE-HVS004 45 CY8C4146LWE-HVS105
22 CY8C4146LDE-HVS014 46 CY8C4146LWE-HVS115
23 CY8C4146LDE-HVS004X 47 CY8C4146LWE-HVS105X
24 CY8C4146LDE-HVS014X 48 CY8C4146LWE-HVS115X
