  1. Packs
  2. perf_counter
Change Log
Version 2.5.3: Nov. 2, 2025
Get Pack
      Release v2.5.3
      - Allowing specifying a variable as the name string in __cycleof__().
      - Improves real-time performance and memory footprint.
      - When perfc_init(false), users can call perf_counter APIs in other ISRs (and/or the global interrupt is disabled).
      - Fixs the support for Cortex-M23.
      - Updates the support for Armv8.1-m PMU.
      - Allows users to call us realted APIs when system timer frequency is lower than 1MHz.
      - Other minor updates
Version 2.5.2: July 25, 2025
Get Pack
      Release v2.5.2
      - Fixes the support for Arm Compiler 5
      - Improves the compatibility with C++
      - Adds support for the hardware architectures that use growing-upward stacks
      - Uses format specifiers defined in inttypes.h
      - Allows users to disable the aliases of the deprecated APIs
      - Fixes GCC support
Version 2.5.1: July 18, 2025
Get Pack
      Release v2.5.1
      - Adds a macro ISR() to measure the maximum stack usage of a given Cortex-M exception handler.
      - Allows users to define the macro __PERFC_STACK_WATERMARK_U32__ to override the default watermark, i.e. 0xDEADBEEF.
      - Fixes issues found in __stack_usage__() and __stack_usage_max__().
      - Other minor changes.
Version 2.5.0: July 14, 2025
Get Pack
      Release v2.5.0
      - Adds a helper service for coroutines
      - Adds a coroutine based protoThread code template
      - Adds prefix 'perfc_' to APIs and Macros
      - Supports feed the watchdog in perfc_delay_ms(), originally called delay_ms()
      - Supports yield from perfc_delay_ms() with coroutine's help
      - Adds __stack_usage__() and __stack_usage_max__()
Version 2.4.0: Dec. 8, 2024
Get Pack
      - Avoid time roll-back in some rare cases
      - Add macros for protoThread
      - Some minor changes
Version 2.3.3: July 27, 2024
Get Pack
      Release v2.3.3
      - Enhance foreach() and with() with __typeof__()
      - Always use systick_wrapper_gnu.s when Arm Compiler 6 is detected
      - Some minor fixes
Version 2.3.2: July 6, 2024
Get Pack
      Release v2.3.2
      - Adds __perfc_sync_barrier__() and improves __cycleof__()
      - Some minor fixes
Version 2.3.1: March 12, 2024
Get Pack
      Release v2.3.1
      - Fixed PMU-SysTick-overflow-miscounting issue
Version 2.3.0: Feb. 28, 2024
Get Pack
      Release v2.3.0
      - Support porting to a different architecture
      - Support Armv8.1-m PMU
          * Add __cpu_perf__() for CPI and L1 DCache miss rate
      - Some other minor changes.
Version 2.2.4: Oct. 19, 2023
Get Pack
      - Add support for RT-Thread-nano
      - Add an API for checking stack overflow
      - Improve the support for the Arm Compiler 6.21
Version 2.2.3: Aug. 30, 2023
Get Pack
      - Mitigate time-rolling-back issue when calling get_system_ticks in exception handlers that have higher priorities than the SysTick_Handler.
Version 2.2.2: June 12, 2023
Get Pack
      - Add __cpu_time__
      - Support reconfiguring the SysTick
      - Suppress warnings
Version 2.2.1: May 19, 2023
Get Pack
      - Update perfc_is_time_out_ms and perf_is_time_out_us
Version 2.2.0: May 18, 2023
Get Pack
      - Enhance Timer Services
Version 2.1.0: March 19, 2023
Get Pack
      - Update stop_cycle_counter prototype to solve return-value-overflow issue
      - Provide timer service for EventRecorder automatically
      - Remove the bundle from cmsis-pack
Version 2.0.0: March 2, 2023
Get Pack
      - Add Coremark
Version 1.9.11: Feb. 9, 2023
Get Pack
      - Fix the source variant support for Armv8-M processors
      - Other minor fixes
Version 1.9.10: Nov. 1, 2022
Get Pack
      - Fix the support for RT-Thread
      - Improve the way to import systick wrapper
      - Add get_system_us to avoid 64bit integer divider.
      - Minor Update
Version 1.9.8: Aug. 10, 2022
Get Pack
      - Improve delay accuracy
      - Fix RT-Thread stack-fully-used issue
      - introduce macro __PERF_COUNTER_CFG_USE_SYSTICK_WRAPPER__
Version 1.9.6: June 15, 2022
Get Pack
      - Add RT-Thread Package
      - Add new API update_perf_counter() for notifying perf_counter that SystemCoreClock has been updated
      - Add a macro __perf_counter_printf__ to retarget printf
      - Add a macor __PERF_COUNT_PLATFORM_SPECIFIC_HEADER__ for people to insert a platform specific header file.
      - Add Doxygen
Version 1.9.5: May 20, 2022
Get Pack
      - Add support for Cortex-M85, Star-MC1 and all other Armv8.1-M processors
      - Update Readme
Version 1.9.4: April 13, 2022
Get Pack
      - Mitigate some clang warnings
      - Minor update for RTOS support
Version 1.9.3: Feb. 26, 2022
Get Pack
      - Fix CONNECT macro cannot connect two parameters issue.
      - Add UNUSED_PARAM
      - Add support for C++ env
Version 1.9.2: Feb. 14, 2022
Get Pack
      - Add API get_system_ms() to avoid int64_t divide operation.
      - Add API delay_ms()
Version 1.9.1: Feb. 13, 2022
Get Pack
      - Add preprocessing in perf_counter.h to detect whether GNU extension is enabled or not.
      - Enhance RTOS support
      - Add macro __PERF_COUNTER__ in RTE_Components.h for compile-time detection.
Version 1.8.2: Jan. 29, 2022
Get Pack
      - Fix a bug found in __cycleof__. The __cycle_counter__ was not updated with the measure result.
      - Add macros for version info.
