  1. Packs
  2. KIT_T2G-C-2D_LITE_BSP
The Infineon KKIT_T2G-C-2D_LITE board support pack (BSP):
Supported Devices
This Board support pack (BSP) supports CYT4DNJBZS device (KIT_T2G-C-2D_LITE)
Content in csolution format
Using GCC / IAR Compiler
By default the example Csolution project is configured for the Arm Compiler 6 (AC6). it can be reconfigured for a different compilers. To configure it for the GCC / IAR compilers execute these steps:
  • In the <solution_name>.csolution.yml project file select compiler: GCC for GCC or select compiler: IAR for IAR.
  • Clean and build the project.
