  1. Packs
  2. CMSIS-RTX
Overview
Keil RTX version 5 (RTX5) is a real-time operating system (RTOS) for Arm Cortex-M and Cortex-A processor-based devices that implements the CMSIS-RTOS2 API as its native interface.
Modern microcontroller applications must often serve several concurrent activities. Keil RTX5 manages the switching between the activities. Each activity gets a separate thread which executes a specific task and to simplify the program structure. Keil RTX5 is scalable, and more threads can easily be added later. Threads have a priority allowing faster execution of time-critical parts of a user application.
Keil RTX5 offers services needed in many real-time applications, such as threads, timers, memory and object management, and message exchange. The following image shows the services of Keil RTX5.
Keil RTX5 Overview
Features
Open-source
  • Full-featured, free-to-use commercial-grade RTOS.
  • Shipped under the permissive Apache 2.0 license.
  • Configurable with no restrictions.
  • Publicly developed on GitHub with full source code available.
Easy to use
  • Reduced learning curve leading to faster product development.
  • Provides configuration parameters for the kernel operation and the RTX objects.
  • Configuration wizard annotations make parameter settings clear and intuitive in IDEs.
Safe and secure
Flexible scheduling
Keil RTX5 offers various kernel scheduling options, allowing you to choose the best scheduling for your application.
Pre-emptive
  • Each thread has a different priority and runs until a higher priority thread is ready to run.
  • Commonly used in interactive systems where a device can be in standby or background mode until some input is sent to it.
Round-robin
  • Each thread runs for a fixed period of CPU run-time (time slice).
  • Data loggers or system monitors typically employ round-robin scheduling to sample all sensors or data-sources in turn with no prioritization.
Co-operative
Each thread runs until it is told to pass control to another thread or reaches a blocking OS call. Co-operative multi-tasking can be seen in applications that require a fixed order of execution.
Fully deterministic behavior
  • Known behavior for time critical tasks.
  • Events and interrupts are handled within a predefined time (deadline). Applications can rely on consistent and known process timings.
Low-power mode
Designed for embedded systems
  • Requires minimal MCU resources with a memory footprint as small as 5 KB (ROM).
  • Written for applications running on Arm Cortex-M-based MCUs.
  • Quick run time.
Links
