S32K3X4EVB-Q172
Rev.ACMSIS-Pack is a delivery mechanism for software components and device support for embedded and IoT applications. Learn more.
Core
Cortex-M7
Debug interface
JTAG/SW
Device
S32K344
NXP S32K3X4EVB-Q172
Overview
The S32K3X4EVB-Q172 is an evaluation and development board for general purpose industrial and automotive applications.
Based on the 32-bit Arm® Cortex®-M7 S32K3 MCU in a 172 MaxQFP package, the S32K3X4EVB-Q172 offers dual cores configured in lockstep mode, ASIL D safety hardware, HSE security engine, OTA support, advanced connectivity and low power.
The S32K3X4EVB-Q172 offers a standard-based form factor compatible with the Arduino® UNO pin layout, providing a broad range of expansion board options for quick application prototyping and demonstration.
Schematics
Hardware User Manual
CMSIS-Drivers
This board support pack contains a CMSIS-Driver for the VIO interface. This is a virtual I/O abstraction for peripherals that are typically used in example projects. The Blinky example uses this interface to create a blinking light with the USER LED mounted on the board that can be controlled by the USER BUTTON (SW8).
Virtual Resource | Variable | Physical Resource on S32K3X4EVB-Q172 |
vioBUTTON0 | vioSignalIn.0 | PTB19 (SW6, USER_SW1) |
vioBUTTON1 | vioSignalIn.1 | PTB26 (SW5, USER_SW0 disabled) |
vioLED0 | vioSignalOut.0 | PTA29 (RGBLED0_RED) |
vioLED1 | vioSignalOut.1 | PTA30 (RGBLED0_GREEN) |
vioLED2 | vioSignalOut.2 | PTA31 (RGBLED0_BLUE) |
Refer to the schematics for board connection information.
